Plastic Failure
I have one of the older pinebook pro the 328 128gb to be exact. And I can't help but notice the failure of the plastic around the usb a ports. Is this a known problem if so how would be best be addressed and do other problems exist?
(08-25-2022, 10:00 PM)Atton Wrote: I have one of the older pinebook pro the 328 128gb to be exact. And I can't help but notice the failure of the plastic around the usb a ports. Is this a known problem if so how would be best be addressed and do other problems exist?
Please find the attached the usb port on the other-side is well on its way to similar damage.
  Catastrophic failure of bottom screw mounts zackw 2 1,499 12-31-2022, 01:26 PM
Last Post: josmo
  Pinebook pro Hardware failure: how should I diagnose it? alxndr.psclt 5 4,677 09-08-2021, 09:03 PM
  Pinebook Pro screen failure? BBreeziN 1 2,946 01-08-2021, 03:21 PM
Last Post: member
  Plastic around camera loose, easy fix? poVoq 0 1,852 08-02-2020, 01:34 PM
Last Post: poVoq
Exclamation Firmware/Keyboard Failure on ANSI PBP Jeremiah Cornelius 1 2,943 02-08-2020, 06:59 PM
Last Post: bcnaz
  Plastic Spacers at Hinges - Substitution hmuller 1 2,986 11-15-2019, 12:01 PM
Last Post: hdk
