Pinebook Pro won't boot
I was following the instructions on here https://nullr0ute.com/2021/05/fedora-on-...ebook-pro/, before halfway through the process of flashing u-boot, the screen went black, I assume because the battery ran out, so I plugged it in and now it won't boot up at all, the only feedback I get is the red dot from the charging cable being plugged in and the CPU is warm now. The power indicator on the keyboard no longer lights up. I've attempted to boot with the emmc both enabled and disabled, while on battery and while plugged in, and with the SD card inserted and removed, all to the same result. Is there anything I can do? I believe my spi flash is corrupted.
https://forum.pine64.org/showthread.php?tid=16361
(08-26-2022, 12:58 AM)wangyukunshan Wrote: https://forum.pine64.org/showthread.php?tid=16361
It didn't work for me and I'm not getting the power light when I try to turn it on like they do in this post
Same boat. Booted from SD flashed Manjaro Gnome distro for PbPro to emmc, never turned on again. eMMC switch did nothing. Power button useless. Reset did nothing. Battery or a/c bypass did nothing. Removed eMMC did nothing. Can't get it to power to even try booting from the SD card again.
Absolute trash. F Pine. F Pinebook Pro.
Your impatience and lack of understanding does not imply a bad product or company. I have seen reports of Pinebooks Pro being thrown in the trash. If you feel inclined to do that, please sell it in stead
It seems to me that it has gotten popular lately to flash U-boot (and alternatives) to SPI flash, making troubleshooting more difficult.
The biggest problem I find is making a micro-sd card that actually boots. Most of them that seem to boot rely on a working and cooperative U-boot on the eMMC. The second biggest problem is making sure the PBP is actually turned off after locking up from an errant boot. Then you have to make sure that SPI flash is erased (all zeroes) or is disabled.
I recently went through the list of bootable sd images in the wiki and the first one I could find that actually worked was DietPi, which I was able to use to wipe out the eMMC and recover the system. I would expect you could erase the SPI flash as well. Others have reported other operating system image that work. But I know the DietPi one works.
:wq
[ SRA accepts you ]
(09-03-2022, 07:43 PM)KC9UDX Wrote: I recently went through the list of bootable sd images in the wiki and the first one I could find that actually worked was DietPi, which I was able to use to wipe out the eMMC and recover the system.
All flashed w the same software on the same card? Ugh!
Any idea why it is so finicky? Is the uboot stuff missing from all the other images you tried?
(03-14-2023, 10:08 AM)Bram Wrote: All flashed w the same software on the same card? Ugh!
Yes.  No, I don't know why.   Frankly once I found one that worked, I didn't worry about it anymore.  I wouldn't have expected any to work when the first one didn't; except I had the exact same experience in 2020 when the list was different.  At that time, Chrome OS was the one that I got to work.
:wq
[ SRA accepts you ]
  Pinebook Pro Initial Impressions kunger 443 584,455 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,233 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 373 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 278 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 270 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 205 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 632 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 705 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 754 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 273 01-16-2024, 09:17 AM
Last Post: jbradley419
