pinebook pro not booting
Hello, I got a pinebookpro two days ago and it was not booting, I would press the power button and nothing would happen, neither a red nor green light anywhere nothing was happening neither with a short or long press of the power button.
I read the troubleshooting guide about the emmc switch, but I didn't have the tools to open the computer. Today I got the screwdriver and as I was opening it (so not even touching any switch or anything) I heard some noise coming out of the speakers I checked the screen and the manjaro initial setup screen was there. I closed the computer back and went through the manjaro setup and I checked that everything was working (speakers, microphone, wifi).
I then prepared a SD card to install devuan on the pinebookpro (https://pkgmaster.devuan.org/devuan/dist...rd-images/) and I was able to boot from the SD card and go to the installation process. I arrived to the part when it tells you installation is over please remove the SD card and reboot and I did, but it did not reboot.
At this point I am in a similar state that I has at the beginning I press the power button and nothing happens, no orange or green light, no reaction from the computer at all, it does not boot from the emmc cardm and it does not boot from the SD card (I even disconnected the emmc to try to make sure uboot is takn from the SD card)
Any ideas on what I could do?
Thanks!
It turns out the computer was able to turn on from the SD card (with the MME disconnected), the problem seems to be that the devuan installation was not bootable, I wrote an installing image of a different distribution to the MME and now it bootd normally
  Debian on Pinebook Pro u974615 7 982 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,535 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,126 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,193 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,445 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,220 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,236 08-31-2023, 04:20 PM
Last Post: TRS-80
  Issue with booting Manjaro from encrypted NVMe drive on pbp Cs137 1 967 08-18-2023, 01:58 AM
Last Post: juliamenendez
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,471 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,563 08-07-2023, 01:12 PM
Last Post: myself600
