Replace Pogo Pins / Melted Pogo Pins fix
Today one of my pogo pins melted while connecting an PPP with an empty battery to the keyboard:
[Image: 182243276-41f9e103-1a9a-4a33-84cb-a1406fb10bf3.jpg]
This is a weird thing and if this happens to you, here are some pictures on how you might fix this:
1.) remove all screws on the backcover, including the one behind the white sticker:
[Image: 182243061-cbc9f99d-d830-4cfa-b45d-3c0e5ae05b78.jpg]
2.) Gently remove the whole back cover:
[Image: 182243087-bf161889-da2a-4a78-bf23-253d29cacd6c.jpg]
3.) Clean the PCB contacts with alcohol or some special "Kontakt" cleaner:
[Image: 182243177-4120bab9-37c3-4101-9471-ffbc192b8a39.jpg]
4.) Take a replacement pin (or clean the burnt one) and try to model a new surface with some glue and bring it in place (its terrible work when you have big hands):
[Image: 182243222-1cf5291f-2450-4272-a80b-22d5659c0f1b.jpg]
5.) Wait 24h until the glue is really dry (I know, they say it takes seconds to dry, but thats not true), then clean the pogo pin from any glue with a thin file or sandpaper:
......Picture coming in 24h........
  Wall power through pogo pins? jcun4128 2 1,621 10-15-2022, 08:58 AM
Last Post: jcun4128
  Replace PPP sim card/sd card slot hardware tckosvic 5 4,081 03-13-2022, 12:20 PM
Last Post: tckosvic
