How do I change screen brightness in Dietpi
I need help getting the screen brighter using Dietpi, running on debian bullseye.
(07-01-2022, 01:25 PM)computerc Wrote: running on debian bullseye.
I don't know if this is different of debian, but I think the universal way to so this is to modify `/sys/class/backlight/edp-backlight/brightness`.
Easiest way is to run
# cp /sys/class/backlight/edp-backlight/max_brightness /sys/class/backlight/edp-backlight/brightness
To set the backlight to max brightness.
(The "#" means you need root permissions to do this, on debian I believe this is done with `su`, but you may also have `sudo` installed)
I also found out I could use brightnessctl to control, I use sudo "sudo brightnessctl set <value>"
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 333 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 657 07-13-2023, 05:21 PM
Last Post: owaspfap
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,479 04-01-2023, 03:22 PM
Last Post: TRS-80
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 538 02-16-2023, 10:58 AM
Last Post: cowsay
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,892 09-23-2022, 08:37 PM
Last Post: computerc
  DietPi OS for Pinebook Pro MichaIng 3 4,547 11-19-2021, 01:56 PM
Last Post: MichaIng
  Adjusting screen resolution lead to a black screen Linux-Rob 28 26,592 06-27-2021, 02:12 AM
Last Post: Arwen
  Manjaro Dim Display (Brightness 40%) After Every System Reboot runlinux.run 2 3,111 02-15-2021, 07:04 PM
Last Post: MtnSk8
  Manjaro Issues: Dark Screen & Font size Sally2 1 2,994 12-19-2020, 03:33 PM
Last Post: wove
  dim screen after kernel upgrade bsammon 5 6,715 11-17-2020, 08:50 PM
Last Post: xyzzy
