How to get sleep mode without bricking?
Why doesn't the latest releases for PBP spec Manjaro images patch this sleep brick problem and the drunk mouse pad problem? How to fix sleep brick?
Am I using the wrong version? What is the difference of https://github.com/manjaro-arm/pbpro-ima.../tag/22.04 and https://github.com/manjaro-arm/pbpro-ima...g/20220606
Help me with this and ill change my username.
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 1 958 10-30-2022, 10:09 AM
  Manjaro ARM new version? And hibernate/ sleep mode regretfulpineuser 0 912 06-20-2022, 02:48 PM
Last Post: regretfulpineuser
  cannot boot SD card : "unable to select a mode" alchemist 0 2,120 06-18-2021, 02:03 AM
Last Post: alchemist
  briicked, fix from MASKROM mode? QuinTeknoLife 1 2,117 05-20-2021, 12:28 PM
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 1,797 01-17-2021, 01:50 PM
Last Post: BananaPekan
  Pinebook Pro sleep issue (hinge?) pciman 1 2,843 07-12-2020, 12:48 AM
Last Post: MtnSk8
