Keyboard support broken in Mobian?
On June the 6th I apt upgraded my PinePhone CE running Mobian Bookworm after 2 wks. It prompted me to reboot, and when I did the keyboard was no longer recognised, neither as a battery or as an input source, yet the keyboard battery continued to charge the phone itself.
I suspected this was an issue with the update and started investigating; from what I have gathered the keyboard battery is supported via module ip5xxx_power, and the keyboard itself via module kb151. None of these modules are present in my /lib/modules/5.15-sunxi64/kernel subtree, and I the modification date of kernel/drivers/power matches the 06/06 date.
I understand you can build these modules from source, but I would like to understand why they have disappeared in case this is an issue with Mobian and the maintainers need to be notified. I would appreciate if anyone with a working keyboard could locate these modules and confirm their location.
(06-07-2022, 02:20 AM)MacarioMorenoUK Wrote: On June the 6th I apt upgraded my PinePhone CE running Mobian Bookworm after 2 wks. It prompted me to reboot, and when I did the keyboard was no longer recognised, neither as a battery or as an input source, yet the keyboard battery continued to charge the phone itself.
I have the same issue. Apt updated on 06/06... I have power on and off but the k151 'bar' is missing in Mobian and no keyboard output. Apt update on 07/06 no change.
This has been reported as well in https://forum.pine64.org/showthread.php?tid=16756; basically the last release of the kernel (5.15.41-sunxi64)-1 shipped without kb151 or ip5xxx_power. As suggested by @zltpxqhp69o2 in the thread, an alternative is to use the 5.17 kernel in the unstable release branch:
sudo echo "deb http://repo.mobian-project.org/ unstable main non-free" >> /etc/apt/sources.list.d/mobian.list
sudo apt update
sudo apt install linux-image-5.17-sunxi64
This can then be reversed after the next release of the stable kernel; it is also worth keeping an eye at the mobian tracker: https://gitlab.com/mobian1/devices/sunxi...fee996ceb8 (as pointed out by @Brother Cadfael)
  Mobian and Keyboard tim.senecal 17 4,569 08-10-2022, 02:25 PM
Last Post: MNtinkerer
  keyboard and usb-c oihantto64 17 3,834 07-16-2022, 02:02 AM
Last Post: bokomaru
  Can't find "-" on the keyboard gilwood 1 370 06-05-2022, 12:57 PM
Last Post: tecdroid
  adding some keys to pp keyboard case, pageup, pagedown, f11, f12, maybe others zetabeta 1 439 04-30-2022, 08:18 PM
Last Post: TRS-80
  pine64 keyboard pogo 'no-go' pins --- 3 1,049 04-29-2022, 04:59 AM
Last Post: Humid Stylus
  PinePhone Keyboard KJ6OHG 10 3,169 03-02-2022, 10:38 AM
Last Post: lacriz
  No underscore on pinephone keyboard gilwood 3 992 02-25-2022, 07:43 AM
Last Post: gilwood
  Did i break my wifi with the keyboard? captchasolver 5 1,333 02-10-2022, 03:39 PM
Last Post: pothos
  NEXT KEYBOARD bcnaz 2 967 02-04-2022, 12:38 AM
Last Post: bcnaz
Bug [Support Request] Modem is Failing to Be Accessible FriendlyGecko 3 1,386 11-30-2021, 01:22 PM
Last Post: FriendlyGecko
