Using Android and the Playstore
I have a couple questions about Android.
1. It looks like the latest image for Android 9, SD card is from 2019. Have there been no updates since then? Or has support dropped off?
2. Is there any reason to choose an older version (7, 8)?
It looks like I have to do some work to install the Playstore, whichever version I use. I don't normally use Android but there are a few apps I would like to try. I might be able to set something up with a Linux distribution but it would probably be a lot more work than installing a couple of apps.
  Difficulty installing Android on Rockpro64 spammycheese 0 2,688 02-17-2023, 05:31 AM
Last Post: spammycheese
  Android TV miguelangelaj 2 2,882 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,367 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 10,786 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 2,615 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 24,496 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 13,823 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 3,931 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 27,469 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 2,900 11-20-2020, 04:15 AM
Last Post: Wizzard
