Using soquartz's MIPI DSI1 output
I am currently trying (with no success so far) to start the DSI1 output with a 4-lane DSI panel on the soquartz module, using a RPi CM4 IO board as baseboard. I use a custom panel based on a Fitipower JD9365DA chip (I already have a kernel driver for it, tested on a RPi CM4 on the same baseboard). Note that it is my first project with a module based on a rockchip SoC.
As I understand from the kernel dts bindings documentation and headers, rockchip mipi dsi drivers, and existing quartz-a (which has a dsi0 output) and soquartz dts files, my dts must create the following pipeline by linking peripherals ports (and also enable the video_phy1 node used as dphy by the DSI1 node) :
VOP out (choosed vp0) >> DSI1 in >> DSI1 out >> Panel in
My work is based on a fork of @pgwipeout kernel tree retrieved from https://gitlab.com/pgwipeout/linux-next main branch. I use the u-boot build from https://gitlab.com/pgwipeout/quartz64_ci pipeline artifacts. My rootfs is a custom one based on Alpine's AArch64 rootfs.
Here is my DTS file (only shows the diff from the original rk3566-soquartz-cm4.dts)
&dsi1 {
        status = "okay";
        clock-master;
        ports {
                dsi1_out: port@1 {
                        reg = <1>;
                        #address-cells = <1>;
                        #size-cells = <0>;
                        dsi1_out_panel: endpoint {
                                remote-endpoint = <&panel_in_dsi>;
        mipi_panel: panel@0 {
                compatible = "fitipower,jd9365da";
                reg=<0>;
                backlight = <&panel_backlight>;
                reset-gpios = <&gpio3 RK_PD1 GPIO_ACTIVE_HIGH>;
                port {
                        panel_in_dsi: endpoint {
                                remote-endpoint = <&dsi1_out_panel>;
&dsi1_in {
        dsi1_in_vp0: endpoint@0 {
                reg = <0>;
                remote-endpoint = <&vp0_out_dsi1>;
&video_phy1 {
        status = "okay";
&vp0 {
        vp0_out_dsi1: endpoint@RK3568_VOP2_EP_MIPI1 {
                reg = <RK3568_VOP2_EP_MIPI1>;
                remote-endpoint = <&dsi1_in_vp0>;
&vop {
        assigned-clocks = <&cru DCLK_VOP0>;
        assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
        status = "okay";
&vop_mmu {
        status = "okay";
Everything builds OK, the boards boots properly, and the nodes show up in /sys (got both vop, dsi and my driver, see below), but it seems like nothing is really started. I added some pr_warn() calls in the beginning of my panel driver dsi_probe() function, they never show up in dmesg, and Xorg fails to start with a "no screen detected" message. U-boot seems to detect the video output pipeline after loading the dtb (it tries to load a boot logo since I modified the dts).
# find /sys -name "*dsi*"
/sys/kernel/debug/clk/xin_osc0_mipidsiphy0_g
/sys/kernel/debug/clk/clk_mipidsiphy0_ref
/sys/kernel/debug/clk/xin_osc0_mipidsiphy1_g
/sys/kernel/debug/clk/clk_mipidsiphy1_ref
/sys/kernel/debug/clk/pclk_dsitx_0
/sys/kernel/debug/clk/pclk_dsitx_1
/sys/kernel/debug/clk/pclk_mipidsiphy0
/sys/kernel/debug/clk/pclk_mipidsiphy1
/sys/class/devlink/platform:fe860000.video-phy--platform:fe070000.dsi
/sys/class/devlink/platform:fe040000.vop--platform:fe070000.dsi
/sys/class/devlink/platform:fe070000.dsi--platform:fe040000.vop
/sys/class/devlink/platform:fe070000.dsi--platform:display-subsystem
/sys/class/devlink/platform:fe760000.gpio--platform:fe070000.dsi
/sys/class/devlink/platform:fdd90000.power-management:power-controller--platform:fe070000.dsi
/sys/devices/platform/pinctrl/fe760000.gpio/consumer:platform:fe070000.dsi
/sys/devices/platform/fe040000.vop/consumer:platform:fe070000.dsi
/sys/devices/platform/fe040000.vop/supplier:platform:fe070000.dsi
/sys/devices/platform/fe070000.dsi
/sys/devices/platform/display-subsystem/supplier:platform:fe070000.dsi
/sys/devices/platform/fdd90000.power-management/fdd90000.power-management:power-controller/consumer:platform:fe070000.dsi
/sys/devices/platform/fe860000.video-phy/consumer:platform:fe070000.dsi
/sys/devices/virtual/devlink/platform:fe860000.video-phy--platform:fe070000.dsi
/sys/devices/virtual/devlink/platform:fe040000.vop--platform:fe070000.dsi
/sys/devices/virtual/devlink/platform:fe070000.dsi--platform:fe040000.vop
/sys/devices/virtual/devlink/platform:fe070000.dsi--platform:display-subsystem
/sys/devices/virtual/devlink/platform:fe760000.gpio--platform:fe070000.dsi
/sys/devices/virtual/devlink/platform:fdd90000.power-management:power-controller--platform:fe070000.dsi
/sys/bus/platform/devices/fe070000.dsi
/sys/bus/platform/drivers/inno-dsidphy
/sys/bus/platform/drivers/dw-mipi-dsi-rockchip
/sys/bus/mipi-dsi
/sys/bus/mipi-dsi/drivers/jd9365da-dsi
/sys/firmware/devicetree/base/dsi@fe060000
/sys/firmware/devicetree/base/dsi@fe070000
I have no errors regarding the VOP / DSI / panel in my dmesg / boot logs (see below), and only a warning regarding VOP2 IOMMU allocation which fails and fallbacks to a generic DMA (message : "Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA"), maybe this is related to the problem ?
Retrieving file: /initramfs
reading /initramfs
5185977 bytes read in 433 ms (11.4 MiB/s)
Retrieving file: /vmlinuz
reading /vmlinuz
36727296 bytes read in 3044 ms (11.5 MiB/s)
append: earlycon=uart8250,mmio32,0xfe660000 console=ttyS2,1500000n8 root=/dev/mmcblk0p7 rootwait
Retrieving file: /dtbs/rockchip/rk3566-soquartz-cm4.dtb
reading /dtbs/rockchip/rk3566-soquartz-cm4.dtb
54229 bytes read in 10 ms (5.2 MiB/s)
Fdt Ramdisk skip relocation
## Flattened Device Tree blob at 0x0a100000
   Booting using the fdt blob at 0x0a100000
   Using Device Tree in place at 000000000a100000, end 000000000a1103d4
can't found rockchip,drm-logo, use rockchip,fb-logo
WARNING: could not set reg FDT_ERR_BADOFFSET.
failed to reserve fb-loader-logo memory
Adding bank: 0x00200000 - 0x08400000 (size: 0x08200000)
Adding bank: 0x09400000 - 0x80000000 (size: 0x76c00000)
Total: 6090.334 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 5.17.0 (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16)) 10.2.1 20201103, GNU ld (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16)) 2.35.1.20201028) #10 SMP PREEMPT Wed May 25 20:31:32 CEST 2022
[    0.000000] Machine model: Pine64 RK3566 SoQuartz with CM4-IO Carrier Board
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x7fbb6a40-0x7fbb8fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000083fffff]
[    0.000000]   node   0: [mem 0x0000000009400000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
[    0.000000] cma: Reserved 32 MiB at 0x000000007b800000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 28 pages/cpu s74584 r8192 d31912 u114688
[    0.000000] pcpu-alloc: s74584 r8192 d31912 u114688 alloc=28*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: patching kernel code
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 511496
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xfe660000 console=ttyS2,1500000n8 root=/dev/mmcblk0p7 rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1963604K/2078720K available (19008K kernel code, 3098K rwdata, 7616K rodata, 6016K init, 622K bss, 82348K reserved, 32768K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 58840 entries in 230 pages
[    0.000000] ftrace: allocated 230 pages with 5 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS [mem 0xfd440000-0xfd45ffff]
[    0.000000] GIC: enabling workaround for ITS: Rockchip RK3568 force no_local_cache
[    0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @5d0000 (indirect, esz 8, psz 64K, shr 0)
[    0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @5e0000 (flat, esz 2, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] ITS ALLOCATE PROP WORKAROUND
[    0.000000] GICv3: using LPI property table @0x00000000005f0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000000600000
[    0.000000] random: get_random_bytes called from start_kernel+0x784/0x974 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001592] Console: colour dummy device 80x25
[    0.002170] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.003188] pid_max: default: 32768 minimum: 301
[    0.003747] LSM: Security Framework initializing
[    0.004295] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.005044] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.008176] cblist_init_generic: Setting adjustable number of callback queues.
[    0.008902] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.009670] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.010647] rcu: Hierarchical SRCU implementation.
[    0.011666] Platform MSI: interrupt-controller@fd440000 domain created
[    0.012651] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[    0.013753] EFI services will not be available.
[    0.014970] smp: Bringing up secondary CPUs ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.017098] Detected VIPT I-cache on CPU1
[    0.017149] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.017173] GICv3: CPU1: using allocated LPI pending table @0x0000000000610000
[    0.017246] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.019069] Detected VIPT I-cache on CPU2
[    0.019115] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.019137] GICv3: CPU2: using allocated LPI pending table @0x0000000000620000
[    0.019194] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.020943] Detected VIPT I-cache on CPU3
[    0.020985] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.021006] GICv3: CPU3: using allocated LPI pending table @0x0000000000630000
[    0.021059] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.021220] smp: Brought up 1 node, 4 CPUs
[    0.028956] SMP: Total of 4 processors activated.
[    0.029425] CPU features: detected: 32-bit EL0 Support
[    0.029931] CPU features: detected: 32-bit EL1 Support
[    0.030437] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.031306] CPU features: detected: Common not Private translations
[    0.031923] CPU features: detected: CRC32 instructions
[    0.032432] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.032996] CPU features: detected: LSE atomic instructions
[    0.033543] CPU features: detected: Privileged Access Never
[    0.034088] CPU features: detected: RAS Extension Support
[    0.034621] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.075977] CPU: All CPU(s) started at EL2
[    0.079080] devtmpfs: initialized
[    0.094020] KASLR disabled due to lack of seed
[    0.094737] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.095752] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.097810] pinctrl core: initialized pinctrl subsystem
[    0.098867] regulator-dummy: no parameters, enabled
[    0.099913] DMI not present or invalid.
[    0.100962] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.104267] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.105284] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.106341] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.107231] audit: initializing netlink subsys (disabled)
[    0.108037] audit: type=2000 audit(0.108:1): state=initialized audit_enabled=0 res=1
[    0.109398] thermal_sys: Registered thermal governor 'fair_share'
[    0.109411] thermal_sys: Registered thermal governor 'bang_bang'
[    0.110014] thermal_sys: Registered thermal governor 'step_wise'
[    0.110605] thermal_sys: Registered thermal governor 'user_space'
[    0.111194] thermal_sys: Registered thermal governor 'power_allocator'
[    0.112463] cpuidle: using governor menu
[    0.113759] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.114620] ASID allocator initialised with 65536 entries
[    0.115308] Serial: AMBA PL011 UART driver
[    0.130543] platform fe070000.dsi: Fixing up cyclic dependency with fe040000.vop
[    0.156804] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.158423] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.159998] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.161578] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.163033] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.192035] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.192715] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.193414] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.194077] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.195944] cryptd: max_cpu_qlen set to 1000
[    0.197724] ACPI: Interpreter disabled.
[    0.198989] sdmmc_pwr: 3300 mV, disabled
[    0.199588] reg-fixed-voltage sdmmc_pwr: sdmmc_pwr supplying 3300000uV
[    0.200479] vcc12v_dcin: 12000 mV, enabled
[    0.201054] reg-fixed-voltage vcc12v_dcin: vcc12v_dcin supplying 12000000uV
[    0.201975] vcc_5v: will resolve supply early: vin
[    0.202456] reg-fixed-voltage vcc_5v: Looking up vin-supply from device tree
[    0.203158] vcc_5v: supplied by vcc12v_dcin
[    0.203579] vcc12v_dcin: could not add device link regulator.3: -ENOENT
[    0.204327] vcc_5v: 5000 mV, enabled
[    0.204872] reg-fixed-voltage vcc_5v: vcc_5v supplying 5000000uV
[    0.205671] vcc3v3_pcie: will resolve supply early: vin
[    0.206217] reg-fixed-voltage 3v3_pcie: Looking up vin-supply from device tree
[    0.206940] vcc3v3_pcie: supplied by vcc12v_dcin
[    0.207410] vcc12v_dcin: could not add device link regulator.4: -ENOENT
[    0.208123] vcc3v3_pcie: 3300 mV, enabled
[    0.208700] reg-fixed-voltage 3v3_pcie: vcc3v3_pcie supplying 3300000uV
[    0.210041] iommu: Default domain type: Passthrough
[    0.211749] vgaarb: loaded
[    0.212390] SCSI subsystem initialized
[    0.213050] libata version 3.00 loaded.
[    0.213783] usbcore: registered new interface driver usbfs
[    0.214396] usbcore: registered new interface driver hub
[    0.215047] usbcore: registered new device driver usb
[    0.216395] pps_core: LinuxPPS API ver. 1 registered
[    0.216889] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.217819] PTP clock support registered
[    0.218256] EDAC MC: Ver: 3.0.0
[    0.219820] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    0.220570] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.222389] Advanced Linux Sound Architecture Driver Initialized.
[    0.224874] clocksource: Switched to clocksource arch_sys_counter
[    0.322314] VFS: Disk quotas dquot_6.6.0
[    0.322799] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.323824] pnp: PnP ACPI: disabled
[    0.337466] NET: Registered PF_INET protocol family
[    0.338224] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.340504] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.341496] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.342416] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.343391] TCP: Hash tables configured (established 16384 bind 16384)
[    0.344188] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.344921] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.345846] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.347034] RPC: Registered named UNIX socket transport module.
[    0.347623] RPC: Registered udp transport module.
[    0.348087] RPC: Registered tcp transport module.
[    0.348549] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.350234] PCI: CLS 0 bytes, default 64
[    0.350989] Trying to unpack rootfs image as initramfs...
[    0.362029] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    0.363750] kvm [1]: IPA Size Limit: 40 bits
[    0.364208] kvm [1]: GICv3: no GICV resource entry
[    0.364684] kvm [1]: disabling GICv2 emulation
[    0.365184] kvm [1]: GIC system register CPU interface enabled
[    0.366006] kvm [1]: vgic interrupt IRQ9
[    0.366697] kvm [1]: VHE mode initialized successfully
[    0.370914] Initialise system trusted keyrings
[    0.371761] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[    0.383167] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.385008] NFS: Registering the id_resolver key type
[    0.385554] Key type id_resolver registered
[    0.385971] Key type id_legacy registered
[    0.386494] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.387161] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.388275] ksmbd: The ksmbd server is experimental, use at your own risk.
[    0.388989] ntfs3: Max link count 4000
[    0.389364] ntfs3: Read-only LZX/Xpress compression included
[    0.390316] 9p: Installing v9fs 9p2000 file system support
[    0.444795] Key type asymmetric registered
[    0.445250] Asymmetric key parser 'x509' registered
[    0.445868] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.446602] io scheduler mq-deadline registered
[    0.447052] io scheduler kyber registered
[    0.452735] phy phy-fe8a0000.usb2phy.0: Looking up phy-supply from device tree
[    0.453539] vcc_5v: could not add device link phy-fe8a0000.usb2phy.0: -ENOENT
[    0.456172] phy phy-fe840000.phy.1: Looking up phy-supply from device tree
[    0.456953] phy phy-fe840000.phy.1: Looking up phy-supply property in node /phy@fe840000 failed
[    0.462563] rockchip-dw-pcie 3c0000000.pcie: Looking up vpcie3v3-supply from device tree
[    0.463955] rockchip-dw-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[    0.464720] rockchip-dw-pcie 3c0000000.pcie: Parsing ranges property...
[    0.465542] rockchip-dw-pcie 3c0000000.pcie:       IO 0x0301000000..0x03010fffff -> 0x0001000000
[    0.466443] rockchip-dw-pcie 3c0000000.pcie:      MEM 0x0302000000..0x033fffffff -> 0x0002000000
[    0.467530] rockchip-dw-pcie 3c0000000.pcie: iATU unroll: enabled
[    0.468136] rockchip-dw-pcie 3c0000000.pcie: Detected iATU regions: 8 outbound, 8 inbound
[    0.627604] Freeing initrd memory: 5064K
[    1.577243] rockchip-dw-pcie 3c0000000.pcie: Phy link never came up
[    1.578136] rockchip-dw-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00
[    1.578833] pci_bus 0000:00: root bus resource [bus 00-0f]
[    1.579383] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x1000000-0x10fffff])
[    1.580308] pci_bus 0000:00: root bus resource [mem 0x302000000-0x33fffffff] (bus address [0x02000000-0x3fffffff])
[    1.581477] pci_bus 0000:00: scanning bus
[    1.581934] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400
[    1.582568] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[    1.583355] pci 0000:00:00.0: supports D1 D2
[    1.583784] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    1.584357] pci 0000:00:00.0: PME# disabled
[    1.589944] pci_bus 0000:00: fixups for bus
[    1.590375] pci 0000:00:00.0: scanning [bus 01-ff] behind bridge, pass 0
[    1.591207] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[    1.592276] pci_bus 0000:01: scanning bus
[    1.597036] pci_bus 0000:01: fixups for bus
[    1.597455] pci_bus 0000:01: bus scan returning with max=01
[    1.598014] pci 0000:00:00.0: scanning [bus 01-ff] behind bridge, pass 1
[    1.598685] pci_bus 0000:00: bus scan returning with max=ff
[    1.599259] pci 0000:00:00.0: BAR 6: assigned [mem 0x302000000-0x30200ffff pref]
[    1.599996] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    1.600780] pcieport 0000:00:00.0: assign IRQ: got 49
[    1.605989] pcieport 0000:00:00.0: PME: Signaling with IRQ 50
[    1.606709] pcieport 0000:00:00.0: saving config space at offset 0x0 (reading 0x35661d87)
[    1.607520] pcieport 0000:00:00.0: saving config space at offset 0x4 (reading 0x100507)
[    1.608309] pcieport 0000:00:00.0: saving config space at offset 0x8 (reading 0x6040001)
[    1.609142] pcieport 0000:00:00.0: saving config space at offset 0xc (reading 0x10000)
[    1.609925] pcieport 0000:00:00.0: saving config space at offset 0x10 (reading 0x0)
[    1.610681] pcieport 0000:00:00.0: saving config space at offset 0x14 (reading 0x0)
[    1.611434] pcieport 0000:00:00.0: saving config space at offset 0x18 (reading 0xff0100)
[    1.612229] pcieport 0000:00:00.0: saving config space at offset 0x1c (reading 0xf0)
[    1.613012] pcieport 0000:00:00.0: saving config space at offset 0x20 (reading 0xfff0)
[    1.613793] pcieport 0000:00:00.0: saving config space at offset 0x24 (reading 0x1fff1)
[    1.614581] pcieport 0000:00:00.0: saving config space at offset 0x28 (reading 0x0)
[    1.615335] pcieport 0000:00:00.0: saving config space at offset 0x2c (reading 0x0)
[    1.616087] pcieport 0000:00:00.0: saving config space at offset 0x30 (reading 0x0)
[    1.616841] pcieport 0000:00:00.0: saving config space at offset 0x34 (reading 0x40)
[    1.617625] pcieport 0000:00:00.0: saving config space at offset 0x38 (reading 0x0)
[    1.618382] pcieport 0000:00:00.0: saving config space at offset 0x3c (reading 0x20131)
[    1.620559] EINJ: ACPI disabled.
[    1.628003] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.628767] dma-pl330 fe530000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    1.632992] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.633748] dma-pl330 fe550000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    1.636678] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    1.642654] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.646853] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 39, base_baud = 1500000) is a 16550A
[    1.647970] serial serial0: tty port ttyS1 registered
[    1.649910] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 40, base_baud = 1500000) is a 16550A
[    1.651089] printk: console [ttyS2] enabled
[    1.651878] printk: bootconsole [uart8250] disabled
[    1.654256] fe6b0000.serial: ttyS0 at MMIO 0xfe6b0000 (irq = 41, base_baud = 1500000) is a 16550A
[    1.658922] rockchip-vop2 fe040000.vop: Adding to iommu group 0
[    1.659491] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[    1.659676] rockchip-vop2: probe of fe040000.vop failed with error -2
[    1.666267] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.678418] brd: module loaded
[    1.687580] loop: module loaded
[    1.688638] zram: Added device: zram0
[    1.689289] megasas: 07.719.03.00-rc1
[    1.699787] tun: Universal TUN/TAP device driver, 1.6
[    1.700578] e100: Intel(R) PRO/100 Network Driver
[    1.701040] e100: Copyright(c) 1999-2006 Intel Corporation
[    1.701624] e1000: Intel(R) PRO/1000 Network Driver
[    1.702060] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    1.702659] e1000e: Intel(R) PRO/1000 Network Driver
[    1.703103] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.703697] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.704180] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.704747] Intel(R) 2.5G Ethernet Linux Driver
[    1.705192] Copyright(c) 2018 Intel Corporation.
[    1.705674] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.706230] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.706810] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver
[    1.707352] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    1.708192] ixgbevf: Intel(R) 10 Gigabit PCI Express Virtual Function Network Driver
[    1.708910] ixgbevf: Copyright (c) 2009 - 2018 Intel Corporation.
[    1.709714] i40e: Intel(R) Ethernet Connection XL710 Network Driver
[    1.710274] i40e: Copyright (c) 2013 - 2019 Intel Corporation.
[    1.711105] ixgb: Intel(R) PRO/10GbE Network Driver
[    1.711544] ixgb: Copyright (c) 1999-2008 Intel Corporation.
[    1.712137] iavf: Intel(R) Ethernet Adaptive Virtual Function Network Driver
[    1.712762] Copyright (c) 2013 - 2018 Intel Corporation.
[    1.713523] Intel(R) Ethernet Switch Host Interface Driver
[    1.714015] Copyright(c) 2013 - 2019 Intel Corporation.
[    1.714777] ice: Intel(R) Ethernet Connection E800 Series Linux Driver
[    1.715359] ice: Copyright (c) 2018, Intel Corporation.
[    1.717889] usbcore: registered new interface driver rtl8192cu
[    1.718943] usbcore: registered new interface driver rtl8xxxu
[    1.719726] usbcore: registered new interface driver ax88179_178a
[    1.720565] VFIO - User Level meta-driver version: 0.3
[    1.726454] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.727048] ehci-pci: EHCI PCI platform driver
[    1.727515] ehci-platform: EHCI generic platform driver
[    1.728292] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.728894] ohci-pci: OHCI PCI platform driver
[    1.729375] ohci-platform: OHCI generic platform driver
[    1.730927] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.731445] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.732321] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    1.733278] xhci-hcd xhci-hcd.0.auto: irq 18, io mem 0xfcc00000
[    1.735113] hub 1-0:1.0: USB hub found
[    1.735509] hub 1-0:1.0: 1 port detected
[    1.736366] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.736911] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    1.737607] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.738298] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.739889] hub 2-0:1.0: USB hub found
[    1.740280] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    1.741382] usbcore: registered new interface driver usb-storage
[    1.743753] i2c_dev: i2c /dev entries driver
[    1.753014] rtc rtc0: Power loss detected, invalid time
[    1.753746] rtc-pcf85063 1-0051: registered as rtc0
[    1.755213] rtc rtc0: Power loss detected, invalid time
[    1.755685] rtc-pcf85063 1-0051: hctosys: unable to read the hardware clock
[    1.759189] arm-scmi firmware:scmi: Failed. SCMI protocol 21 not active.
[    1.761867] rockchip-thermal fe710000.tsadc: Missing tshut mode property, using default (gpio)
[    1.762642] rockchip-thermal fe710000.tsadc: Missing tshut-polarity property, using default (low)
[    1.766171] cpu cpu0: Looking up cpu-supply from device tree
[    1.766964] arm-scmi firmware:scmi: Failed. SCMI protocol 19 not active.
[    1.769178] sdhci: Secure Digital Host Controller Interface driver
[    1.769732] sdhci: Copyright(c) Pierre Ossman
[    1.770563] Synopsys Designware Multimedia Card Interface Driver
[    1.771680] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.774616] ledtrig-cpu: registered to indicate activity on CPUs
[    1.776020] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    1.776713] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.777880] usbcore: registered new interface driver usbhid
[    1.778381] usbhid: USB HID core driver
[    1.779101] ashmem: initialized
[    1.780702] SPI driver st-accel-spi has no spi_device_id for st,lis302dl-spi
[    1.781386] SPI driver st-accel-spi has no spi_device_id for st,lis3lv02dl-accel
[    1.782045] SPI driver st-accel-spi has no spi_device_id for st,lis3dh-accel
[    1.782668] SPI driver st-accel-spi has no spi_device_id for st,lsm330d-accel
[    1.783296] SPI driver st-accel-spi has no spi_device_id for st,lsm330dl-accel
[    1.783933] SPI driver st-accel-spi has no spi_device_id for st,lsm330dlc-accel
[    1.784577] SPI driver st-accel-spi has no spi_device_id for st,lis331dlh-accel
[    1.785245] SPI driver st-accel-spi has no spi_device_id for st,lsm330-accel
[    1.785870] SPI driver st-accel-spi has no spi_device_id for st,lsm303agr-accel
[    1.786515] SPI driver st-accel-spi has no spi_device_id for st,lis2dh12-accel
[    1.787152] SPI driver st-accel-spi has no spi_device_id for st,lng2dm-accel
[    1.787772] SPI driver st-accel-spi has no spi_device_id for st,h3lis331dl-accel
[    1.788423] SPI driver st-accel-spi has no spi_device_id for st,lis331dl-accel
[    1.799089] NET: Registered PF_PACKET protocol family
[    1.799788] 9pnet: Installing 9P2000 support
[    1.800258] Key type dns_resolver registered
[    1.801281] registered taskstats version 1
[    1.801660] Loading compiled-in X.509 certificates
[    1.806486] zswap: loaded using pool zstd/zsmalloc
[    1.881039] vbus: will resolve supply early: vin
[    1.881485] reg-fixed-voltage vbus: Looking up vin-supply from device tree
[    1.882115] vbus: supplied by vcc_5v
[    1.882446] vcc_5v: could not add device link regulator.5: -ENOENT
[    1.883082] vbus: 5000 mV, enabled
[    1.883627] reg-fixed-voltage vbus: vbus supplying 5000000uV
[    1.884489] vcc5v0_sys: will resolve supply early: vin
[    1.884985] reg-fixed-voltage vcc5v0_sys: Looking up vin-supply from device tree
[    1.885653] vcc5v0_sys: supplied by vbus
[    1.886010] vbus: could not add device link regulator.6: -ENOENT
[    1.886642] vcc5v0_sys: 5000 mV, enabled
[    1.887181] reg-fixed-voltage vcc5v0_sys: vcc5v0_sys supplying 5000000uV
[    1.888039] vcc3v3_sys: will resolve supply early: vin
[    1.888502] reg-fixed-voltage vcc3v3_sys: Looking up vin-supply from device tree
[    1.889199] vcc3v3_sys: supplied by vcc5v0_sys
[    1.889604] vcc5v0_sys: could not add device link regulator.7: -ENOENT
[    1.890247] vcc3v3_sys: 3300 mV, enabled
[    1.890770] reg-fixed-voltage vcc3v3_sys: vcc3v3_sys supplying 3300000uV
[    1.894026] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    1.896492] vdd_cpu: will resolve supply early: vin
[    1.896978] fan53555-regulator 0-001c: Looking up vin-supply from device tree
[    1.897627] vdd_cpu: supplied by vcc5v0_sys
[    1.898010] vcc5v0_sys: could not add device link regulator.8: -ENOENT
[    1.901574] vdd_cpu: 800 <--> 1150 mV at 1025 mV, enabled
[    1.904410] rk808 0-0020: chip id: 0x8090
[    1.936888] random: fast init done
[    1.983599] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.984184] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.987263] vdd_logic: will resolve supply early: vcc1
[    1.987731] rk808 0-0020: Looking up vcc1-supply from device tree
[    1.988295] vdd_logic: supplied by vcc3v3_sys
[    1.988694] vcc3v3_sys: could not add device link regulator.9: -ENOENT
[    1.993616] vdd_logic: 500 <--> 1350 mV at 900 mV, enabled
[    1.997223] vdd_gpu: will resolve supply early: vcc2
[    1.997675] rk808 0-0020: Looking up vcc2-supply from device tree
[    1.998231] vdd_gpu: supplied by vcc3v3_sys
[    1.998613] vcc3v3_sys: could not add device link regulator.10: -ENOENT
[    2.003004] vdd_gpu: 500 <--> 1350 mV at 900 mV, enabled
[    2.005244] vcc_ddr: will resolve supply early: vcc3
[    2.005696] rk808 0-0020: Looking up vcc3-supply from device tree
[    2.006252] vcc_ddr: supplied by vcc3v3_sys
[    2.006633] vcc3v3_sys: could not add device link regulator.11: -ENOENT
[    2.010091] vcc_ddr: at 500 mV, enabled
[    2.012690] vdd_npu: will resolve supply early: vcc4
[    2.013180] rk808 0-0020: Looking up vcc4-supply from device tree
[    2.013738] vdd_npu: supplied by vcc3v3_sys
[    2.014120] vcc3v3_sys: could not add device link regulator.12: -ENOENT
[    2.018036] vdd_npu: 500 <--> 1350 mV at 900 mV, enabled
[    2.020750] vcc_1v8: will resolve supply early: vcc9
[    2.021237] rk808 0-0020: Looking up vcc9-supply from device tree
[    2.021795] vcc_1v8: supplied by vcc3v3_sys
[    2.022177] vcc3v3_sys: could not add device link regulator.13: -ENOENT
[    2.025610] vcc_1v8: 1800 mV, enabled
[    2.028536] vdda0v9_image: will resolve supply early: vcc5
[    2.029067] rk808 0-0020: Looking up vcc5-supply from device tree
[    2.029626] vdda0v9_image: supplied by vcc3v3_sys
[    2.030053] vcc3v3_sys: could not add device link regulator.14: -ENOENT
[    2.034036] vdda0v9_image: 900 mV, enabled
[    2.036520] vdda_0v9: will resolve supply early: vcc5
[    2.037014] rk808 0-0020: Looking up vcc5-supply from device tree
[    2.037572] vdda_0v9: supplied by vcc3v3_sys
[    2.037960] vcc3v3_sys: could not add device link regulator.15: -ENOENT
[    2.041434] vdda_0v9: 900 mV, enabled
[    2.044000] vdda0v9_pmu: will resolve supply early: vcc5
[    2.044482] rk808 0-0020: Looking up vcc5-supply from device tree
[    2.045074] vdda0v9_pmu: supplied by vcc3v3_sys
[    2.045487] vcc3v3_sys: could not add device link regulator.16: -ENOENT
[    2.049441] vdda0v9_pmu: 900 mV, enabled
[    2.051576] vccio_acodec: will resolve supply early: vcc6
[    2.052065] rk808 0-0020: Looking up vcc6-supply from device tree
[    2.052622] vccio_acodec: supplied by vcc3v3_sys
[    2.053080] vcc3v3_sys: could not add device link regulator.17: -ENOENT
[    2.056555] vccio_acodec: 3300 mV, enabled
[    2.059087] vccio_sd: will resolve supply early: vcc6
[    2.059546] rk808 0-0020: Looking up vcc6-supply from device tree
[    2.060100] vccio_sd: supplied by vcc3v3_sys
[    2.060490] vcc3v3_sys: could not add device link regulator.18: -ENOENT
[    2.064487] vccio_sd: 1800 <--> 3300 mV at 3300 mV, enabled
[    2.067278] vcc3v3_pmu: will resolve supply early: vcc6
[    2.067752] rk808 0-0020: Looking up vcc6-supply from device tree
[    2.068308] vcc3v3_pmu: supplied by vcc3v3_sys
[    2.068711] vcc3v3_sys: could not add device link regulator.19: -ENOENT
[    2.072700] vcc3v3_pmu: 3300 mV, enabled
[    2.075247] vcca_1v8: will resolve supply early: vcc7
[    2.075705] rk808 0-0020: Looking up vcc7-supply from device tree
[    2.076260] vcca_1v8: supplied by vcc3v3_sys
[    2.076648] vcc3v3_sys: could not add device link regulator.20: -ENOENT
[    2.080154] vcca_1v8: 1800 mV, enabled
[    2.082635] vcca1v8_pmu: will resolve supply early: vcc7
[    2.083117] rk808 0-0020: Looking up vcc7-supply from device tree
[    2.083672] vcca1v8_pmu: supplied by vcc3v3_sys
[    2.084084] vcc3v3_sys: could not add device link regulator.21: -ENOENT
[    2.087556] vcca1v8_pmu: 1800 mV, enabled
[    2.089682] vcca1v8_image: will resolve supply early: vcc7
[    2.090180] rk808 0-0020: Looking up vcc7-supply from device tree
[    2.090736] vcca1v8_image: supplied by vcc3v3_sys
[    2.091163] vcc3v3_sys: could not add device link regulator.22: -ENOENT
[    2.094640] vcca1v8_image: 1800 mV, enabled
[    2.096696] vcc_3v3: will resolve supply early: vcc9
[    2.097185] rk808 0-0020: Looking up vcc9-supply from device tree
[    2.097743] vcc_3v3: supplied by vcc3v3_sys
[    2.098126] vcc3v3_sys: could not add device link regulator.23: -ENOENT
[    2.100589] vcc_3v3: at 3300 mV, enabled
[    2.101720] SWITCH_REG2: no parameters, enabled
[    2.102299] rk808 0-0020: Looking up vcc8-supply from device tree
[    2.102858] SWITCH_REG2: supplied by vcc3v3_sys
[    2.109809] input: rk805 pwrkey as /devices/platform/fdd40000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
[    2.123006] rk808-rtc rk808-rtc: registered as rtc1
[    2.124546] lp855x 2-002c: Looking up power-supply from device tree
[    2.125901] lp855x 2-002c: Looking up enable-supply from device tree
[    2.126501] lp855x 2-002c: Looking up enable-supply property in node /i2c@fe5b0000/backlight@2c failed
[    2.131960] cpu cpu0: Looking up cpu-supply from device tree
[    2.139220] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio1-supply from device tree
[    2.139683] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    2.139836] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    2.139873] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    2.139883] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    2.139951] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 34,32 bit host data width,256 deep fifo
[    2.140107] dwmmc_rockchip fe2c0000.mmc: Looking up vmmc-supply from device tree
[    2.140329] sdhci-dwcmshc fe310000.mmc: Looking up vmmc-supply from device tree
[    2.140742] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    2.141454] dwmmc_rockchip fe2c0000.mmc: Looking up vqmmc-supply from device tree
[    2.141892] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    2.146336] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 33,32 bit host data width,256 deep fifo
[    2.147306] dwmmc_rockchip fe2b0000.mmc: Looking up vmmc-supply from device tree
[    2.148148] dwmmc_rockchip fe2b0000.mmc: Looking up vqmmc-supply from device tree
[    2.149119] mmc_host mmc0: card is polling.
[    2.149847] sdhci-dwcmshc fe310000.mmc: Looking up vqmmc-supply from device tree
[    2.150351] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    2.151006] mmc_host mmc2: card is non-removable.
[    2.151043] rockchip-iodomain fdc20000.syscon:io-domains: Looking up pmuio2-supply from device tree
[    2.154737] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio1-supply from device tree
[    2.159835] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio2-supply from device tree
[    2.163047] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio3-supply from device tree
[    2.164418] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio4-supply from device tree
[    2.165672] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.166585] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio5-supply from device tree
[    2.167894] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio6-supply from device tree
[    2.169210] rockchip-iodomain fdc20000.syscon:io-domains: Looking up vccio7-supply from device tree
[    2.171614] panfrost fde60000.gpu: clock rate = 594000000
[    2.172114] panfrost fde60000.gpu: bus_clock rate = 500000000
[    2.172655] panfrost fde60000.gpu: Looking up mali-supply from device tree
[    2.173660] mmc_host mmc2: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    2.174663] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    2.175347] panfrost fde60000.gpu: features: 00000000,13de77ff, issues: 00000000,00000400
[    2.176064] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    2.177134] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    2.178789] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 0
[    2.180503] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    2.181279] rk_gmac-dwmac fe010000.ethernet: Looking up phy-supply from device tree
[    2.182570] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    2.183205] rk_gmac-dwmac fe010000.ethernet: TX delay(0x30).
[    2.183704] rk_gmac-dwmac fe010000.ethernet: RX delay(0x10).
[    2.184207] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    2.184785] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    2.187279] mmc1: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    2.190349] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    2.191166] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    2.191822] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    2.192288] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    2.192985] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    2.193642] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    2.194259] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    2.194880] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    2.195375] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.196139] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    2.196812] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    2.197403] rk_gmac-dwmac fe010000.ethernet: Using 32 bits DMA width
[    2.231028] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    2.231979] mmc0: new high speed SDHC card at address 27ea
[    2.233388] mmcblk0: mmc0:27ea SE04G 3.64 GiB
[    2.240363]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
[    2.299383] mmc_host mmc2: Bus speed (slot 0) = 150000000Hz (slot req 150000000Hz, actual 150000000HZ div = 0)
[    2.341757] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.362389] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.363123] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    2.363885] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    2.367355] ALSA device list:
[    2.367630]   No soundcards found.
[    2.368168] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    2.373631] Freeing unused kernel memory: 6016K
[    2.388918] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    2.396957] Run /init as init process
[    2.397295]   with arguments:
[    2.397562]     /init
[    2.397770]   with environment:
[    2.398050]     HOME=/
[    2.398263]     TERM=linux
[    2.447266] Alpine Init 3.6.0-r0
[    2.448479] Loading boot drivers...
* Loading boot drivers: [    2.463803] Loading boot drivers: ok.
ok.
[    2.469123] Mounting root...
* Mounting root: [    2.602729] hub 1-1:1.0: USB hub found
[    2.603156] hub 1-1:1.0: 4 ports detected
[    2.657066] Error: Driver 'lp855x' is already registered, aborting...
[    2.704939] dwmmc_rockchip fe2c0000.mmc: Successfully tuned phase to 238
[    2.709442] mmc2: new ultra high speed SDR104 SDIO card at address 0001
[    3.312526] EXT4-fs (mmcblk0p7): mounted filesystem with writeback data mode. Quota mode: none.
[    3.314435] Mounting root: ok.
I also looked for power domains and clocks configuration in case some peripheral stays in standby / is not clocked, but failed to find what could cause my problem (as I just start working on RK356x SoCs, I may have missed something).
From what I saw on patchwork it seems like there is ongoing work on the VOP2 / DSI code in mainline, maybe I can try to rebase on mainline ?
If that's a driver issue, I am willing to give some time to provide a patch and testing to get it to work (but may need some insights from more experienced people on this SoC).
I will continue my tests / debugging and post my findings, but if anybody with more experience on this board has insights / clues / ideas (or even better, a solution  Smile ), that really can help me.
axelm Wrote:From what I saw on patchwork it seems like there is ongoing work on the VOP2 / DSI code in mainline, maybe I can try to rebase on mainline ?
Indeed. pgwipeout's tree uses an early vop2 patchset, the one in mainline has had many revisions since then. Reportedly MIPI-DSI was working at some point but stopped working in the later revisions on the patchset I believe. A lot of things are in flux and it's half-merged at the moment, so a bit messy to play with.
Your best bet is probably kernel 5.18 with the iommu patchset (referenced in the vop2 cover letter) and the vop2 v11 patchset on top, and then try to get DSI working there. 5.19 will be messier due to the device tree stuff not being merged.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
  How force HDMI out in soquartz rahmanshaber 0 286 11-15-2023, 03:51 PM
Last Post: rahmanshaber
  SOQuartz Linux Builds stormwyrm 1 441 11-13-2023, 02:53 AM
Last Post: diederik
  SOQuartz Blade PXE Boot NCLI 1 808 05-05-2023, 09:49 AM
Last Post: CounterPillow
  SOQuartz Getting a working build dl-m10 7 3,661 01-23-2023, 06:38 PM
Last Post: diederik
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 1,225 07-21-2022, 01:08 PM
Last Post: Randomuser
  PCIe not working on custom board (soquartz) dferrg 1 1,995 02-23-2022, 04:31 AM
Last Post: dferrg
