Is It Possible to Set Up Boinc In this Ver of Ubuntu?
Is it possible to set up Boinc in this version of Ubuntu?
(07-06-2016, 05:24 PM)Bob123456789 Wrote: Is it possible to set up Boinc in this version of Ubuntu?
You can try it by followin this link:
https://boinc.berkeley.edu/wiki/Installi..._on_Ubuntu
I'm not going to try it on my system (I don't care, and I don't want to screw up the card).
The worst that will happen is that it won't work, or it will screw up the SD card, and you just have to start over... backup before you try it.
Big Grin
I have tried it using those instructions and wasn't successful. That's what prompted the question.
I first followed those steps (open a terminal window) and after following this instruction:
sudo aptitude install boinc-client boinc-manager
I got the following error:
sudo: aptitude: command not found
I then was able to install Boinc client and manager after installing the Synaptic Package manager.
Maybe I was not doing something correctly?
Search YouTube, I saw a video about it not too long ago.
I managed to install boinc manager by simply using sudo apt-get install boinc.
After it benchmarked, sadly it says there is no work, I assume that for the project I was trying (SETI), that arm64 is not supported. Not sure if any others are?
  Ubuntu server 20.04 request phi0x 2 5,355 12-30-2020, 08:02 PM
Last Post: phi0x
  SPI on ubuntu IlyaM 4 9,219 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 8,644 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 10,953 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 641,213 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 8,763 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 10,036 08-03-2017, 03:52 PM
Last Post: Luke
  Ubuntu boot very slow with wifi driver remainder 9 20,807 08-03-2017, 07:23 AM
Last Post: victorssantos
  Recovering root access in Ubuntu Scientomancer 3 5,922 07-28-2017, 02:53 PM
Last Post: Scientomancer
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 2,901 07-08-2017, 09:34 AM
Last Post: petec
