Cannot find "-" on the pinephone keyboard
I have tried all the left Shift + Fn + all the F1-F10 keys and cannot find a "-". The use of F5 or F6 produce the "~". The use of F7 or F9 produce the "_". The use of the F8 or F10 produce the "+". Finally, the use of F1 or F2 produce the "|". Everything else on the keyboard appears to work as well as the charging and disconnect of my pinephone from charging using the keyboard battery. Am I overlooking something and why is there redundancy in some of the symbols produced using the F keys? Any help is appreciated. Thanks
For me the minus key is under F7.
You might need to change the keyboard layout.
I think you can find the current configuration by going
# xkbcomp $DISPLAY output.xkb
(https://wiki.archlinux.org/title/X_keyboard_extension)
Look for the section that controls the number row, for me it's like
xkb_symbols "(unnamed)" {
    name[group1]="English (US)";
    key  <ESC> {         [          Escape ] };
    key <AE01> {
        type= "FOUR_LEVEL",
        symbols[Group1]= [               1,          exclam,             bar,        NoSymbol ]
    key <AE02> {
        type= "FOUR_LEVEL",
        symbols[Group1]= [               2,              at,       backslash,        NoSymbol
    key <AE07> {
        type= "FOUR_LEVEL",
        symbols[Group1]= [               7,       ampersand,           minus,        NoSymbol ]
Maybe your layout doesn't define the third level of keys. At least on PPP it was recently broken on Manjaro.
If that's the problem there is an updated keyboard map here
https://codeberg.org/HazardChem/PinePhon...h/main/tty
This is what I did for Manjaro plasma on PPP
https://forum.pine64.org/showthread.php?tid=16640
Thank you for your suggestions. Currently running Mobian, have to see if your suggestions are applicable.
(05-20-2022, 11:40 AM)gilwood Wrote: I have tried all the left Shift + Fn + all the F1-F10 keys and cannot find a "-". The use of F5 or F6 produce the "~". The use of F7 or F9 produce the "_". The use of the F8 or F10 produce the "+". Finally, the use of F1 or F2 produce the "|". Everything else on the keyboard appears to work as well as the charging and disconnect of my pinephone from charging using the keyboard battery. Am I overlooking something and why is there redundancy in some of the symbols produced using the F keys? Any help is appreciated. Thanks
I described this problem in post 1 and post 5 of this thread,
https://forum.pine64.org/showthread.php?tid=15787
I use ManjaroARM, but I think this is the kernel keyboard driver, not specific to an OS. I show the two layers of symbols you get with Fn-Num Key and Shift-Fn-Numkey and their redundancies.
The fix for this is installing the userspace driver which gets you what is printed on the keys and f-Keys using the Pine key + num key. A method for doing this for Mobian is described here:
https://forum.pine64.org/showthread.php?tid=16153
  Case for Pinephone totilele 13 7,180 04-11-2024, 11:48 AM
Last Post: gramonyl
  keyboard case charging but not typing new2pinephone 18 5,739 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 8,319 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 631 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 423 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,152 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 449 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,230 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 513 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 615 10-21-2023, 02:55 AM
