Can't find "-" on the keyboard
I have tried all the left Shift + Fn + all the F1-F10 keys and cannot find a "-". The use of F5 or F6 produce the "~". The use of F7 or F9 produce the "_". The use of the F8 or F10 produce the "+". Finally, the use of F1 or F2 produce the "|". Everything else on the keyboard appears to work as well as the charging and disconnect of my pinephone from charging using the keyboard battery. Am I overlooking something and why is there redundancy in some of the symbols produced using the F keys? Any help is appreciated. Thanks
Got the same problem. It should be PINE + 5 but doesn't work
debugging via
xkbcli interactive-wayland
showed me that Pine Key (SUPER_L) reacts with any key but not the upper row.
I know that it worked using user space driver but pinephone_keyboard but after last os upgrade I didn't get ppkb to work..
Maybe there's a bug in pinephone_keyboard driver?
  pinephone keyboard + dock question tuxcall 7 2,638 02-05-2024, 03:17 PM
Last Post: wigan
  PinePhone Keyboard KJ6OHG 11 7,886 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone keyboard layout with manjaro plasma daemonbsd 0 933 03-02-2023, 05:01 AM
Last Post: daemonbsd
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,102 02-20-2023, 12:14 AM
  Mobian and Keyboard tim.senecal 17 11,478 08-10-2022, 02:25 PM
Last Post: MNtinkerer
  keyboard and usb-c oihantto64 17 10,134 07-16-2022, 02:02 AM
Last Post: bokomaru
  wlan0 Cannot find device systemcrash.. 1 1,040 06-30-2022, 01:37 PM
Last Post: systemcrash..
  Keyboard support broken in Mobian? MacarioMorenoUK 2 1,733 06-08-2022, 02:34 AM
Last Post: MacarioMorenoUK
  adding some keys to pp keyboard case, pageup, pagedown, f11, f12, maybe others zetabeta 1 1,285 04-30-2022, 08:18 PM
Last Post: TRS-80
  pine64 keyboard pogo 'no-go' pins --- 3 2,466 04-29-2022, 04:59 AM
Last Post: Humid Stylus
