"Repository" for Safe Software/Apps?
Hi first time Linux user here.  I'm aware Linux operating systems usually have something called a "repository" that provides a safe way to get a wide variety of popular software for your Linux device.  So on Linux Mint for example, I think it's called "software manager."
Just booted up my PinePhone... I'm wondering if there is something similar here to get me started that I'm not seeing.
(05-12-2022, 05:09 PM)MarsColonist Wrote: Hi first time Linux user here.  I'm aware Linux operating systems usually have something called a "repository" that provides a safe way to get a wide variety of popular software for your Linux device.  So on Linux Mint for example, I think it's called "software manager."
I moved your question to the PinePhone section of the forum. Mind that asking such questions in the community chat is usually the fastest way to get a reply, please see https://wiki.pine64.org/wiki/Main_Page#Chat_Platforms for the channel list.
Regarding your question there should be such a software manager too, it's probably called "Discover". You can also install Firefox from there.
Many people use the terminal for such tasks however, as it is more reliable and gives a better output of the things happening. Under Manjaro the tool to update the system and installing and removing packages is called "pacman". To update the system you can run "sudo pacman -Syu", to install applications you can run "sudo pacman -S APPNAME". I strongly recommend you to get yourself familiar with the terminal usage, if that's not the case already.
"Regarding your question there should be such a software manager too, it's probably called "Discover". You can also install Firefox from there."
And so any app I see in Discover is safe to install as far as being confident it doesn't have viruses/spyware or whatever, right? Because it's a Linux repository?
  Writing apps/programs for pine phone katesfb 7 4,981 03-11-2024, 10:42 PM
Last Post: Emelia525
  Android bank apps ionmich 4 1,717 12-12-2023, 01:01 PM
Last Post: mannzrespouse
  Basic question: KDE apps on GNOME and vice versa jojuma 4 1,236 06-15-2023, 01:42 PM
Last Post: jojuma
  Buiding apps for pinephone katesfb 9 8,601 06-03-2022, 07:29 AM
Last Post: presire
  Favorite software? Scary Guy 0 963 02-16-2022, 01:28 PM
Last Post: Scary Guy
  Paid apps for Pinephone Vinibrito 5 3,741 02-14-2022, 10:47 AM
Last Post: Vinibrito
  unable to install any software pine-user1 2 1,493 11-09-2021, 01:07 AM
Last Post: ryo
  software jesica 3 3,010 10-30-2021, 08:27 AM
Last Post: beta-user
  list of linux native apps/softwares for pinephone on the wiki alexandre 7 7,321 10-26-2021, 11:56 PM
Last Post: bcnaz
  Why are certain apps so slow? gamerminstrel 10 7,179 10-18-2021, 02:01 PM
Last Post: bosi564
