PPKB certain keys not working after kernel update
(05-10-2022, 03:14 PM)rotwang Wrote:
Quote:You can create similar keymaps for XKB, for use with Xorg server
I know this is what is in the megi post. Has anyone actually done this... and maybe they have a keymap for xkb for the pinephone keyboard I could get a copy of?
I too couldn't get megi's loadkeys example to work in console. I could live without it in console if I could get my under-number-keys characters back in X.
I've been reading and reading the arch documentation on xkb, but not making any serious progress. (Is it me, or is that page much more opaque than usual for Arch documentation?)
I got AltG working as modifier to reach the under-number-keys by editing the beginning of
/usr/share/X11/xkb/symbols/en
default partial alphanumeric_keys modifier_keys
xkb_symbols "basic" {
    name[Group1]= "English (US)";
    key <TLDE> {        [    grave,    asciitilde      ]      };
    key <AE01> {        [        1,    exclam,      bar        ]      };
    key <AE02> {        [        2,    at,          backslash  ]      };
    key <AE03> {        [        3,    numbersign      ]      };
    key <AE04> {        [        4,    dollar,         ]      };
    key <AE05> {        [        5,    percent,    asciitilde        ]      };
    key <AE06> {        [        6,    asciicircum, grave      ]      };
    key <AE07> {        [        7,    ampersand,  minus      ]      };
    key <AE08> {        [        8,    asterisk,    equal      ]      };
    key <AE09> {        [        9,    parenleft,  underscore ]      };
    key <AE10> {        [        0,    parenright,  plus      ]      };
    key <AE11> {        [    minus,    underscore      ]      };
    key <AE12> {        [    equal,    plus            ]      };
    key <AD01> {        [        q,    Q              ]      };
    key <AD02> {        [        w,    W              ]      };
    key <AD03> {        [        e,    E              ]      };
    key <AD04> {        [        r,    R              ]      };
    key <AD05> {        [        t,    T              ]      };
    key <AD06> {        [        y,    Y              ]      };
    key <AD07> {        [        u,    U              ]      };
    key <AD08> {        [        i,    I              ]      };
    key <AD09> {        [        o,    O              ]      };
    key <AD10> {        [        p,    P              ]      };
    key <AD11> {        [ bracketleft,  braceleft      ]      };
    key <AD12> {        [ bracketright, braceright      ]      };
    key <AC01> {        [        a,    A              ]      };
    key <AC02> {        [        s,    S              ]      };
    key <AC03> {        [        d,    D              ]      };
    key <AC04> {        [        f,    F              ]      };
    key <AC05> {        [        g,    G              ]      };
    key <AC06> {        [        h,    H              ]      };
    key <AC07> {        [        j,    J              ]      };
    key <AC08> {        [        k,    K              ]      };
    key <AC09> {        [        l,    L              ]      };
    key <AC10> {        [ semicolon,    colon          ]      };
    key <AC11> {        [ apostrophe,  quotedbl        ]      };
    key <AB01> {        [        z,    Z              ]      };
    key <AB02> {        [        x,    X              ]      };
    key <AB03> {        [        c,    C              ]      };
    key <AB04> {        [        v,    V              ]      };
    key <AB05> {        [        b,    B              ]      };
    key <AB06> {        [        n,    N              ]      };
    key <AB07> {        [        m,    M              ]      };
    key <AB08> {        [    comma,    less            ]      };
    key <AB09> {        [    period,    greater        ]      };
    key <AB10> {        [    slash,    question        ]      };
    key <BKSL> {        [ backslash,        bar        ]      };
    include "level3(ralt_switch)"
I found this, which looks like a nicer way of solving the problem (compared to the wtype option) with swmo and possibly phosh as well: https://codeberg.org/HazardChem/PinePhone_Keyboard .
Awesome thanks!
I ended up downgrading the kernel. But that's inevitably a temporary solution.
(05-18-2022, 04:53 PM)mr_growl Wrote: I found this, which looks like a nicer way of solving the problem (compared to the wtype option) with swmo and possibly phosh as well: https://codeberg.org/HazardChem/PinePhone_Keyboard .
I confirm it works for Phosh. In my case, Danctnix already includes necessary xkb configuration, and all I needed to do, was to follow the instructions at the bottom of https://wiki.mobian-project.org/doku.php...ccessories to add systemd service override, which adds a necessary environment variable for Phosh service.
Which instructions? If you wouldn't mind spoon feeding me a little.
I think you are talking about this part "Add the following to /etc/systemd/system/phosh.service.d/override.conf" but phosh.service.d doesnt exist.
Came here to post asking for help getting the userland driver working, but it seems like I am not the only one having issues.
For anyone looking for step by step:
sudo systemctl edit phosh.service
Add this between the comment lines as directed:
[Service]
Environment=XKB_DEFAULT_MODEL=ppkb
Write out, close and reboot.
AltG will now provide the correct symbols. It works for me.
I pulled this from the github issues section, user by the name of Dan-Sun who clarified sado1 who I believe is the same person I responded to initially. So thanks to both of you. I had to add sudo in front of the systemctl command.
Hey all
We try to keep track of the issues there too https://github.com/dreemurrs-embedded/Pi...issues/376 until it's working via the kernel or another easy solution.
The last solution works, but the FN key would be better option because you still need to use it for arrow keys etc… This means that you have to move your thumb a little bit more Smile And I use the pine64 key instead because I like to use altg to switch between applications.
(05-30-2022, 01:24 PM)Dan-Sun Wrote: Hey all
Agree, but at least I can now use "|\-_" and thanks again for your write-up on github.
I assume I could change it to the pine key in Accessibility? Which one is the pine key there?
Edit: Yep its there, "Left Super"
(04-22-2022, 01:34 PM)EdnZWOYJWMiU Wrote: The wtype config equivalent for Phosh would be:
1. Check existing custom keybindings:
$ gsettings get org.gnome.settings-daemon.plugins.media-keys custom-keybindings
['/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/']
2. Declare new keybindings (offset by the existing keybindings index, "custom0" in this case)
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/ name 'wtype1'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/ command 'wtype "|"'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/ binding '<Super>1'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom2/ name 'wtype2'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom2/ command 'wtype "\\"'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom2/ binding '<Super>2'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom3/ name 'wtype5'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom3/ command 'wtype "~"'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom3/ binding '<Super>5'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom4/ name 'wtype6'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom4/ command 'wtype "`"'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom4/ binding '<Super>6'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom5/ name 'wtype7'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom5/ command 'wtype -k "Minus"'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom5/ binding '<Super>7'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom6/ name 'wtype8'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom6/ command 'wtype "="'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom6/ binding '<Super>8'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom7/ name 'wtype9'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom7/ command 'wtype "_"'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom7/ binding '<Super>9'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom8/ name 'wtype0'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom8/ command 'wtype "+"'
gsettings set  org.gnome.settings-daemon.plugins.media-keys.custom-keybinding:/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom8/ binding '<Super>0'
3. Update custom keybindings list
gsettings set  org.gnome.settings-daemon.plugins.media-keys custom-keybindings "['/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom0/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom1/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom2/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom3/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom4/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom5/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom6/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom7/', '/org/gnome/settings-daemon/plugins/media-keys/custom-keybindings/custom8/']"
It's laggy, but better than nothing.
Quote:Couldn't get file descriptor referring to the console
Loadkeys is for console (not Wayland)
Smile   Note: this method worked for me on pmos phos wayland.   Also had to install wtype from repository.
(05-13-2022, 01:56 AM)primary-suaerkraut Wrote: I got AltG working as modifier to reach the under-number-keys by editing the beginning of
I did this and it worked, but not immediately. It worked after I rebooted the system.
I wish I could have done this without rebooting.  Unfortunately l am unfamiliar with Arch Linux ARM and am now kinda locked-in to it.
  Disappearing arroe keys ionmich 1 648 09-03-2023, 07:41 AM
Last Post: _radv_
  satellite doesn't work after update shulamy 1 816 05-17-2023, 10:34 PM
  FDE installer not working user641 0 736 03-04-2023, 02:55 AM
Last Post: user641
  Latest update broke my install user641 8 3,475 02-22-2023, 05:54 AM
Last Post: gregb49
  Ringtone not working through external speaker... tk1107 2 2,005 03-13-2022, 11:34 PM
Last Post: tk1107
  Keyboard function keys vgnmnky 4 3,324 02-25-2022, 07:04 AM
Last Post: vgnmnky
  Can't update or install software P3TER 31 22,961 02-12-2022, 05:07 PM
Last Post: IHaveALinuxPhone
  Last update bricked my pine phone :( lacriz 6 3,957 01-25-2022, 07:52 AM
Last Post: kqlnut
  Latest update broke my cellular 112113101098101077 1 2,170 05-05-2021, 06:41 AM
Last Post: 112113101098101077
  Issue: nf modules not found in kernel? theD0ctor 5 5,628 03-15-2021, 07:41 AM
Last Post: Danct12
