Audio Pot Board Questions
I couldn't find out, what this big white 6 pin socket on the board is used for. Someone has a clue?
The other question is: there is this jellow jumper which selects the clock signal. In the schematics drawing one can see, that pin 1 selects the board's clock. Now I wonder which pin is pin 1.
regards,
Hans-Peter
> ... white 6 pin socket ...
It simply pulls out the signal as shown in the schematic.
Probably, it seems to be a terminal assuming the case of connecting another I2S-device (DAC etc...) to the outside.
> ... which pin is pin 1.
Look at the back of the board, there is a (50M / MCLK) silk mark.
The part where 50M is printed is pin 1.
However, even if you select the MCLK side, it will not work properly in many cases.
This is because many kernels are not set to output MCLK to the outside.
You can find such a post by searching the forum thread here.
(04-17-2022, 06:54 PM)t4_4t Wrote: > ... white 6 pin socket ...
Many thanks, now it's clear to me.Currently, I'm running a volumio image on the rock64 and it let's me select the 50M side. Which is fine for me Big Grin .
Hi vfr400racer, I'm new to this and am building a music streamer and am trying to load volumio on the Rock64. I see you have an image running. I have a Rock64 V3 and have tried loading an image of both Volumio V2 and V3 with no success, I can load other OS's such as DietPi for Rock64 but the Volumio ones from this forum seem to flash ok but dont load - no red/white led activity even after 30 mins or so and no display. Just wondering if you had any suggestions.
Hi does anyone have a volumio image running on a Rock64 V3 board?
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 966 04-26-2023, 11:38 PM
  Rock64 4K60P HDR Media Board Computer 64 bit MarkHaysHarris777 8 17,309 07-14-2021, 11:52 PM
Last Post: jontumontu
  Help connecting a dvb board in the right gpio pins cosmodeal 0 2,126 11-11-2020, 12:48 PM
Last Post: cosmodeal
  Rock64 stereo audio dac add-on board with RockPro64 Tim13 1 3,487 07-08-2019, 07:15 PM
  Rock64 Stereo Audio DAC add-on board Hukmut 3 5,561 06-15-2019, 07:56 AM
Last Post: MiiCode2
  "ROCK 64 STEREO AUDIO DAC ADD-ON BOARD", Is it okay if I turn on the power ? t4_4t 4 5,789 01-09-2019, 01:02 AM
Last Post: t4_4t
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 3,691 12-01-2018, 03:53 AM
Last Post: jovval
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD angelscream09 7 8,331 11-21-2018, 07:02 PM
Last Post: antonv
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD Sketch killor 4 6,594 11-12-2018, 07:37 AM
Last Post: killor
  ROCK 64 board unresponsive S265 1 2,567 08-05-2018, 06:51 AM
Last Post: paradise
