When is a Release?
When is a Factory?
When is a Beta?
In Manjaro
When is a Factory?
When is a Beta?
In Manjaro
Stable Beta Factory Release
When is a Release?
When is a Factory? When is a Beta? In Manjaro
05-15-2022, 08:38 PM
Disclaimer: I don't own a PinePhone Pro, (but I do own a Pinebook Pro with the same SoC / CPU).
Are you sure your "USB-C hub with DP out" device uses DisplayPort protocol on the phone side? The original USB-C alternate mode for video was DisplayPort. However, the HDMI people wanted the same treatment, so they created a different USB-C alternate mode for HDMI, which is totally in-compatible with "USB-C alternate mode for DisplayPort:". A USB-C alternate mode for video device can have any monitor connector on it, like HDMI, DisplayPort or VGA. A simple, (or complex), converter is needed. However, the SoC / CPU used in the PinePhone Pro, (and Pinebook Pro), requires USB-C alternate mode DISPLAYPORT. Without that, it won't work. (Of course, software support is also required....) https://gas-stationsnearme.com/ Vendors have been a bit vague on what there device specifications are, at times. Some outright leave off what the host side protocol is, USB-C alt. mode DisplayPort, or USB-C alt. mode HDMI. Good luck. Maybe someone else has better information. |
Is Manjaro Plasma stable for anyone? | projectcato | 120 | 53,654 |
04-18-2023, 08:26 PM Last Post: mburns |
Factory AOSP image but for your SD card! | Danct12 | 14 | 8,447 |
04-03-2023, 06:21 PM Last Post: strungar |
PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls | X0X0X0X0X0 | 0 | 1,098 |
11-02-2022, 02:09 PM Last Post: X0X0X0X0X0 |
Megapixels - Camera App - Works w. Beta NOT Pro | iwm | 3 | 2,959 |
11-01-2022, 02:13 PM Last Post: mburns |
Manjaro Plasma Beta 11 sleep issue after 3/22 update | Fred Zyphal | 6 | 3,940 |
05-22-2022, 12:37 PM Last Post: magdesign |
Manjaro-phosh beta 22 release won't boot after update | tckosvic | 1 | 1,522 |
02-28-2022, 09:46 AM Last Post: tckosvic |
Factory AOSP image source? | krazey | 0 | 871 |
02-01-2022, 03:53 PM Last Post: krazey |
Siglo interfaces w. Beta not Pro. | iwm | 0 | 825 |
01-05-2022, 02:01 PM Last Post: iwm |
