Unable to unlock after locking on phosh and plasma
Hey all I've been having an issue that makes using my new PPP pretty much impossible :'( every time the screen locks, automatically or manually, it can not be unlocked. I press the power button or tap the screen and nothing happens and I must manually reboot the phone only to be faced with the same problem again. And the phone is still on, as I can hear the up and down volume sounds the I press the volume buttons. Same results with u-boot, tow-boot, manjaro phosh, manjaro plasma and running the os from emmc or SD...
  [WIP] KDE Plasma Mobile 6.0 Builds & Ports dorkydev 4 410 03-18-2024, 09:43 AM
  Command lines to remove the Phosh UI dorkydev 1 252 02-12-2024, 11:56 AM
Last Post: nekonosuke
  The Mobian Phosh Experience mburns 1 798 11-18-2023, 08:21 AM
Last Post: crocspot
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 581 11-09-2023, 07:39 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 549 10-14-2023, 11:57 AM
Last Post: mburns
  Manajaro Plasma 6 files break unstable updates, 6-30 mburns 5 1,484 07-20-2023, 11:19 AM
Last Post: mburns
  Manjaro Plasma unstable branch glitch mburns 2 995 06-21-2023, 08:03 AM
Last Post: mburns
  The Phosh Web app vs Angelfish mburns 0 612 06-19-2023, 11:57 AM
Last Post: mburns
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 2 874 06-11-2023, 04:12 PM
Last Post: ArchiMark
  How do I tell Phosh that my app is mobile friendly? Barugon 5 1,519 06-05-2023, 09:24 PM
Last Post: Barugon
