How long does it take to boot from SD card?
Hi everyone! Just got my PPP today and have been tinkering with it. I've been having massive problems just trying to get the default experience to function in any capacity (currently, when I boot the phone, I enter my passcode and then I just get an unresponsive white screen)
 So I figured I'd try flashing a different OS to the SD card and booting from that. So I flashed archlinux- archlinux-pinephone-pro-phosh-20220222.img
 How long is it supposed to take? I booted the phone, it vibrated for a few seconds, went through a terminal-looking loading screen, and now I've been stuck at some kind of loading screen (A phone with a penguin on it with a swirling loading circle) for about 20 minutes now. Did I do something wrong or is this normal? [url=https://github.com/dreemurrs-embedded/Pine64-Arch/releases/download/20220222/archlinux-pinephone-pro-phosh-20220222.img.xz][/url]
Issue solved!
Solution: I wasn't using a fast enough microSD card. I switched to a SanDisk Extreme 128gb micro SDXC I and it boots to SD card just fine now. The card that didn't work was a micro SDHC
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 44,555 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 1,258 02-02-2024, 07:07 PM
Last Post: reky
  What to do if your PinePhone Pro does not boot fxc 19 19,269 09-10-2023, 03:19 AM
Last Post: fxc
  Factory AOSP image but for your SD card! Danct12 14 8,300 04-03-2023, 06:21 PM
Last Post: strungar
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 1,757 02-18-2023, 06:14 PM
Last Post: fxc
  tow-boot installation problem techariah 2 1,476 02-16-2023, 02:50 PM
Last Post: techariah
  create tow boot .img fox95 6 3,011 10-21-2022, 11:40 AM
Last Post: fox95
  Phone wont turn on with any SD Card inserted Ausfaller 3 2,391 07-21-2022, 10:20 AM
Last Post: Ausfaller
  No display on early boot after Manjaro update robocone 0 836 07-07-2022, 05:47 AM
Last Post: robocone
  Latest Manjaro-Phosh and Arch-Phosh won't boot grinzie 6 3,795 07-01-2022, 02:01 PM
Last Post: Chief
