mobile data
I'm on US mobile and had data and mms working but a couple of upates and upgrades later no data connection. Still have phone and sms capabiltiy but no data. I have tried mulitple apns no luck. I flashed Biktorgj's firmware and recovery several times and different versions no luck. Phone shows 4G connection but no data. Wifi and bluetooth work fine. I'm running 2/20/22 weekly no help so went back to unstable still no help.
Curious, did you swap in an activated sim card, or activate the sim card in your pine phone.?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I'm seeing similar symptoms.
Specifically, my problem seems to be DNS.
If I run a command:
curl http://pine64.org
I get an error:
curl: (6) Could not resolve host: pine64.org
But if I try to reach the IP of pine64.org directly:
curl http://91.219.133.83
I get a little success message.
This impacts my ability to use the internet, get/send MMS, etc. Wifi still works (though not for MMS).
Sounds like this bug that's hit Mobian and maybe others. You can downgrade networkmanager or try one of the workarounds listed.
https://gitlab.freedesktop.org/NetworkMa...issues/931
(02-23-2022, 08:05 PM)bcnaz Wrote: Curious,  did you swap in an activated sim card,  or activate the sim card in your pine phone.?
I activated the sim with my pinephone last year when I got it. I had everything working until sometime around the end of Jan or the beginning of Feb.
(02-24-2022, 07:38 AM)wibble Wrote: Sounds like this bug that's hit Mobian and maybe others. You can downgrade networkmanager or try one of the workarounds listed.
Thanks, this was the issue. For me the resolvconf solution did not help, but the networkmanager downgrade did.
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 799 12-13-2023, 01:24 AM
Last Post: oldschool
  how to backup user data? Uturn 1 664 08-30-2023, 05:23 AM
  New Zealand network providers mobile data Linux2thabone 3 3,261 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,211 07-07-2023, 12:06 PM
Last Post: jovval
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,308 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 691 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,214 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  Cannot call at several mobile phones Gon 3 1,307 05-04-2023, 05:18 AM
Last Post: Gon
  cell data and MMS on AT+T prepaid ossands 2 1,436 10-13-2022, 07:28 AM
Last Post: ossands
Lightbulb pinephone mobile dock jasmin763 2 1,692 06-06-2022, 09:06 AM
Last Post: 98cwitr
