Keyboard Case Power Management Daemon
(04-16-2022, 08:01 PM)PineFLOWn Wrote:
(04-16-2022, 04:17 PM)estokes Wrote:
(02-18-2022, 02:40 PM)estokes Wrote: Hi, I've made an attempt at writing the daemon Megi described in his blog post about the keyboard case. It's gone well enough that I thought it was time to share.
https://github.com/estokes/pinephone-kbpwrd
The focus is on maximizing efficiency by avoiding moving charge into the main battery where possible. I'm open to discussion, and especially feedback and data.
Megi is integrating this functionality into the kernel (where it honestly belongs IMHO). As such my project is deprecated.
https://xnux.eu/log/#065
Your contribution to the PinePhone project is much appreciated! Smile
Though personally I've had no luck getting the Keyboard case working on the PPP, although it works fine on my original PP, I've tried the suggested trick of pushing the pins on the case slightly close to the pogo pins on the phone, but that has made no difference, I cant use either the keyboard functionality or the battery charging functionality.
I'm sorry to hear that, because with the kb case the PPP is a truly amazing device. I also had a lot of problems initially that turned out to be defective pogo pins, after swapping them with my PP pogo pins everything worked beautifully.
Tried that approach that you suggested and the pogo pin swap makes no difference, the keyboard still doesn't work on the PPP.
  Battery meter slowly reducing under keyboard charger robocone 1 1,367 12-26-2022, 09:37 AM
Last Post: robocone
  Manjaro 5.17.5-1 Keyboard stopped working Yst 7 3,919 06-09-2022, 11:12 AM
Last Post: graphicpanda444
  Fix keyboard layout robocone 1 1,744 05-16-2022, 08:03 AM
Last Post: robocone
  Screen keyboard Japanese input issue Yst 1 1,195 04-30-2022, 09:13 PM
Last Post: TRS-80
  PackageKit daemon has crashed dgiffin 10 7,549 03-22-2022, 05:02 PM
Last Post: S H
  Howto Full disk encryption manjaro and detached header (with keyboard) robocone 0 1,710 03-09-2022, 06:53 AM
Last Post: robocone
  Keyboard stopped working -- big problem tckosvic 15 7,427 02-06-2022, 02:04 PM
Last Post: Emilio
