Settings are reset after reboot
I just recently switched from arch to pmos. So far I like it a lot, esp. convergence.
I also just recently received my pinephone keyboard and use it all the time now.
For that reason I would like to have these 2 settings permanently (I change them in the phosh settings app):
1) accessibility -> disable virtual keyboard (I do not need it anymore and it takes up a lot of screen space)
2) display -> set scale from 200% to 150% (makes many apps a lot more useable in landscape mode)
Sadly, whenever I shutdown (in the evening) + start-up the phone (in the morning), these 2 settings are back to their default.
Is there a workaround for this? I am willing to write a script or whatever, this is super annoying to me.
Because you mentioned landscape mode: is there a command (gsettings?) that can change the screen orientation?
For reference, https://wiki.mobian-project.org/doku.php...-variant-2 is the correct method to edit the scaling persistently. I have removed two comments above referencing the wrong path, potentially misleading users (and this already caused damage in the community chat).
(08-15-2023, 02:33 PM)fxc Wrote: For reference, https://wiki.mobian-project.org/doku.php...-variant-2 is the correct method to edit the scaling persistently. I have removed two comments above referencing the wrong path, potentially misleading users (and this already caused damage in the community chat).
I tried this last night on 20230710-0752-postmarketOS-v23.06-phosh-22.2-pine64-pinephone, but the directory etc/phosh does not exist on my phone. I created the directory, copied the file over and made the edit. But the phone would then boot to a console login.
Same thing happened if I edit /usr/share/phosh/.
That would happen if there is a syntax error in the file. Best to provide the whole file here and then we can tell you what went wrong.
For postmarketOS, the instructions are equal: https://wiki.postmarketos.org/wiki/Phosh#Screen_Scaling
Good call. In the original /usr/share/phosh/phoc.ini file, the [output:DSI-1] has a # in front of it. I deleted it and that worked. Thanks.
#[output:DSI-1]
# scale = 2
scale = 1.5
Bonus question, is there anyway to keep that scale but have the full size keyboard?
  The language I've added on settings doesn't appear Gon 2 1,774 08-15-2022, 01:55 PM
Last Post: Gon
  No automatic hub connection on reboot. --- 0 1,038 02-06-2022, 06:52 PM
Last Post: ---
  Poweroff/Reboot fails AndyM 2 2,995 09-18-2021, 06:55 PM
Last Post: jmorris
  Backup user data and settings kratz00 4 5,234 02-28-2021, 03:39 PM
Last Post: kuleszdl
