Pinebook Pro bricked after flashing eMMC
I flashed Manjaro-ARM-kde-plasma-pbpro-21.12 to eMMC from a SD boot as described at https://wiki.pine64.org/wiki/NOOB#Flashi..._a_SD_Boot.
After rebooting, my Pinebook Pro got stuck at the Manjaro logo with the spinning circle.
When I press the Esc key, I see the following message, but the shell does not recognize any keystrokes:
:: running hook [udev]
:: Triggering uevents...
:: running hook [plymouth]
:: performing fsck on '/dev/mmcblk2p2'
ROOT_MNJRO: The filesystem size (according to the superblock) is 15205335 blocks
The physical size of the device is 1763287 blocks
Either the superblock or the partition table is likely to be corrupt!
ROOT_MNJRO: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
        (i.e., without -a or -p options)
ERROR: Bailing out. Run 'fsck /dev/mmcblkp2' manually
********** FILESYSTEM CHECK FAILED **********
*  Please run fsck manually. After leaving  *
*  this maintance shell, the system will    *
*  reboot automatically.                    *
sh: can't access tty; job control turned off
[rootfs /]#
I tried booting from the SD card again, but it does not seem to work as I end up with the same message as above.
Please help!
  Pinebook Pro Initial Impressions kunger 443 584,920 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,238 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 377 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 280 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 273 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 206 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 637 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 708 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Flashing/adjusting on boot and reboot jbradley419 0 276 01-16-2024, 09:17 AM
Last Post: jbradley419
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,479 12-17-2023, 09:29 PM
Last Post: insideau786
