Pinephone keyboard needs pressure
Pinephone Keyboard doesnt work unless I push to backcover or display in place where pogo pins are. Do you have annyone same experience? How did you fix it? I am sure that phone is fully in case, I trided multiple times to put out and in, no difference
Yes' this is the same for me. I sent email to Pine64 support and they responded timely. Still working on a resolution.
https://wiki.pine64.org/wiki/PinePhone_(...er_contact
(02-24-2022, 07:43 AM)wibble Wrote: https://wiki.pine64.org/wiki/PinePhone_(...er_contact
Thanks! The link helped, at least for now. I realized shim need not be metallic, which was my biggest fear. I used slightly stiff card cut to size to prop up the contacts so that the connection was better. It has resolved the issue for me for now. Will be interesting to see how long it lasts. Of course, it will be welcomed if a paper shim is all that is needed.
@terarmot Did your keyboard work in part, or not at all?
I got a keyboard yesterday & am having trouble with it.  It partially works. It snaps into place & the phone recognizes the battery, but the keypad doesn't work.  Before I go shimming things I wonder if that's still the solution.
any reply is appreciated
  keyboard case charging but not typing new2pinephone 18 5,222 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 5,646 01-14-2024, 03:34 PM
Last Post: acid andy
  PinePhone Dock with laptop? Mikey1977Y2J 2 525 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  I've added an I2C connector to the PP keyboard eugenr 0 360 11-26-2023, 07:24 AM
Last Post: eugenr
  Case for Pinephone totilele 12 6,526 11-04-2023, 09:43 AM
Last Post: Negome
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 7,906 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 394 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,114 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 449 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 562 10-21-2023, 02:55 AM
