Broken pinecil (?)
Is there any way to fix a pinecil that does not turn at all? If i plug it in my pc (via dmesg) i get this:
[  111.031189] usb 1-3: new full-speed USB device number 8 using xhci_hcd
[  111.175239] usb 1-3: device descriptor read/64, error -71
[  111.394259] usb 1-3: device descriptor read/64, error -71
[  111.619272] usb 1-3: new full-speed USB device number 9 using xhci_hcd
[  111.763250] usb 1-3: device descriptor read/64, error -71
[  111.986842] usb 1-3: device descriptor read/64, error -71
[  112.096540] usb usb1-port3: attempt power cycle
I hope yes because it tooks 28 days to get to my country.
Your computer's USB doesn't have enough power to run the Pinecil. You need either need a USB type C: PD and QC 3.0 12V-20V 3A power supply or a Barrel Jack: DC5525, 12V-21V DC 3A. Anything less than that and it's designed not to turn on.
(02-15-2022, 02:36 PM)sergio.pantalone Wrote: Your computer's USB doesn't have enough power to run the Pinecil. You need either need a USB type C: PD and QC 3.0 12V-20V 3A power supply or a Barrel Jack: DC5525, 12V-21V DC 3A. Anything less than that and it's designed not to turn on.
Yes, first thing I plug it with my QC charger ( I always used that with my previous pinecil) but nothing. I tried to plug it to my computer and (also in DFU) I get those error and with my previous pinecil it always worked for firmware updates.
  broken? legendslayer 1 381 02-23-2024, 04:35 PM
Last Post: ButteredFly
  Does Pinecil v1 support hakko T12 style tip? xsetiadi 1 1,087 02-02-2024, 03:30 PM
Last Post: SooperPoopyPants
Question Pinecil tip for installing threaded inserts? smcleod 4 1,799 09-11-2023, 06:36 PM
Last Post: kifujin
  Pinecil V2 -boards only DrYak 1 1,642 08-30-2022, 03:59 AM
Last Post: DrYak
  Pinecil 24V mod alex_grach 1 3,178 07-06-2022, 10:35 AM
Last Post: dreieck
  Idea: Pinecil wood burning tip (pyrography)? ijsbeer 4 5,145 10-29-2021, 03:58 AM
Last Post: Fred Zyphal
