Hotspot missing on the pinephone
Hello People,
I have just noticed a missing feature on the pine phone: a hotspot. My pine phone has UB Ports on it and so does my BQ 4.5 original Ubuntu phone. My original phone does have a hotspot in the software but the pine phone doesn't. Can anybody tell me why?
Chris
Not certain "where" it is on the newer UBPorts Op.Sys. but on the Phosh desktops it is the hamburger icon on the top right corner
of your wifi page.
First you must turn off the wifi, then turn on the hotspot.
Using Mobian I have successfully used the hot spot on my orig. Pine phone vers. 1.2a (convergent edition)
==> While I did find working data on both the orig. & the Pro. phones --- I have not tested hot spot on the Pro yet.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(02-12-2022, 11:04 PM)bcnaz Wrote: Not certain  "where"  it is on the newer UBPorts Op.Sys.  but on the Phosh desktops it is the hamburger icon on the top right corner
of your wifi page.
It's in the top part of the screen, you get it by pulling the top part down.
Chris
Is that just an on/off toggle on the pull-down ?
I just changed the sd card in the phone that I had UBPorts running on,
I think I saw the hot spot option back in the Settings
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(02-13-2022, 05:17 AM)bcnaz Wrote: Is that just an on/off toggle on the pull-down ?
Yes, it is. I cannot fathom why it does not have it! My other UB Ports phone has it, so why not the pine phone?
Chris
Chris
Guess you not looking very hard . Right there under Network
  PinePhone - boot from microSD laserpyramid 5 306 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 105,162 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,525 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 464 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 1,940 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 384 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,480 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,608 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Pinephone not booting, always vibrating alexander12 7 4,671 11-22-2023, 06:46 PM
Last Post: Scary Guy
  Pinephone on Verizon chachi 3 993 10-09-2023, 11:26 AM
Last Post: alaraajavamma
