Unable to Update Manjaro Plasma Mobile
So I got my Pro a couple of weeks ago and did the initial update with the `pinephonepro-post-install` or whatever the command was but since then any time I run `sudo pacman -Syu` it says there is nothing to do. What am I missing here?
By default, /etc/pacman-mirrors.conf has the branch set to arm-stable. If you want to update you may choose to change your branch to arm-testing. Make sure your device doesn't lose power when you update after you've run pacman-mirrors with your preferred options.
Or rather, do not let your device enter suspend while updating as the Pinephone Pro currently has problems waking from suspend and seems to require a hard reboot and doing so caused a partial upgrade in my situation which corrupted and required me to manually reinstall a number of packages. Editing ~/.config/powermanagementprofilesrc may be helpful as I believe the idletime values render somewhat pointless the settings you choose in the Plasma Mobile Settings app.
Run command
sudo pacman-mirrors --get-branch
it will show:
'arm-stable'
then if want more frequent updates and less stable environment, run
sudo pacman-mirrors --set-branch testing --api
sudo pacman -Syyu
sudo reboot now
Thanks for the help!
  [WIP] KDE Plasma Mobile 6.0 Builds & Ports dorkydev 5 669 04-15-2024, 08:08 AM
Last Post: u-kidjp
  Can't configure APN/Have no mobile internet zvavybir 4 872 11-22-2023, 12:11 AM
Last Post: zvavybir
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 652 11-09-2023, 07:39 AM
Last Post: mburns
  Arch SXMO Stopped Booting After A Megi Linux Update. mburns 0 465 11-07-2023, 09:52 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 598 10-14-2023, 11:57 AM
Last Post: mburns
  Manajaro Plasma 6 files break unstable updates, 6-30 mburns 5 1,600 07-20-2023, 11:19 AM
Last Post: mburns
  Manjaro Plasma unstable branch glitch mburns 2 1,065 06-21-2023, 08:03 AM
Last Post: mburns
  Manjaro as shipped & camera? hambonius 1 899 06-20-2023, 02:26 PM
Last Post: fxc
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 2 938 06-11-2023, 04:12 PM
Last Post: ArchiMark
  How do I tell Phosh that my app is mobile friendly? Barugon 5 1,658 06-05-2023, 09:24 PM
Last Post: Barugon
