Delete APN setting Arch-Phosh
Question
Is there a way to delete APN settings ? I've got no sms support since i've set it up and would prefer sms over internet for now ...
I believe you just add new APN settings +
Deleting them does not work
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
SMS worked out fine out of the box , but I Had no Internet , after setting up my carrier APN I lost Sms and got internet ... , Guess i'll flash back if it's what it takes
In Phosh/ Mobian, leaving a blank in 'Regions & Languages' in settings 'used to cause problems' with the sms working, don't know if that is the case here.
Think it was maybe 5 or 6 weeks back I tried Dremurs/Arch/Phosh and voice, sms text, data worked then. -- I think hot spot was working, but I didn't take notes.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Not My issue ... I just want to delete the APN config , so basically I just need to know where phosh save that information and delete it
https://www.freedesktop.org/software/Mod...cli.1.html This is one of the few ways I've found so far that you could probably achieve that. You can deactivate the connection in nmtui but if you want to delete it mmcli seems to be your best bet.
Thanks will take a look at that , For now I returned to the stock image without APN setting , but if I could activate and deactivate it with a command I could be able to switch between Internet and SMS
  Command lines to remove the Phosh UI dorkydev 1 315 02-12-2024, 11:56 AM
Last Post: nekonosuke
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 828 11-23-2023, 08:44 AM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 879 11-18-2023, 08:21 AM
Last Post: crocspot
  Arch SXMO Stopped Booting After A Megi Linux Update. mburns 0 462 11-07-2023, 09:52 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 597 10-14-2023, 11:57 AM
Last Post: mburns
  The Phosh Web app vs Angelfish mburns 0 647 06-19-2023, 11:57 AM
Last Post: mburns
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 2 937 06-11-2023, 04:12 PM
Last Post: ArchiMark
  How do I tell Phosh that my app is mobile friendly? Barugon 5 1,653 06-05-2023, 09:24 PM
Last Post: Barugon
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 1,392 05-28-2023, 07:00 AM
  Arch Linux Arm DanctNIX complete setup mikehenson 2 2,435 05-07-2023, 10:00 PM
Last Post: mikehenson
