Keyboard case not charging (or not working) and a possible FIX for both
I had the same issue, keyboard working but no charge unless I pressed the shell and phone.
Since I thought I saw a slight bulge I got suspicious of the plastic "guide" pin in the shell. It would make sense since it seems the pogos closest to it has the problems.
So I took a knife and remove a few millimeters of the plastic guide pin and now my keyboard shell seems to work as it should.
I have no idea what longterm ill effects this might have but for now it works for me.
(04-25-2022, 04:04 AM)Humid Stylus Wrote: Since I thought I saw a slight bulge I got suspicious of the plastic "guide" pin in the shell. It would make sense since it seems the pogos closest to it has the problems.
Thanks for this suggestion.
I started having the same problem with the keyboard not connecting to the PinePhone today. I came to the same conclusion after having no success with contact cleaner and reinstalling the PinePhone a couple of times. If I pressed on the back of the case directly above the pogo pins it would connect, but only while I kept pressing. I was looking at the keyboard case where the pogo pins connect and also noticed the rectangular locating pin. After reading your comment I used a sharp craft knife and shaved a fraction of a mm off the pin. It now connects easily with both keyboard and power.
If it's like the ordinary PinePhone back cover that's a retaining clip not a guide pin, and you sometimes have to press the back cover there for it to engage. The only reason to have a clip in the middle like that is to improve contact on the pogo pins, but if the clip isn't engaged it will make contact worse.
  Case for Pinephone totilele 13 7,015 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 277 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 5,623 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 7,798 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 411 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,095 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 438 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,206 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 504 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 604 10-21-2023, 02:55 AM
