Keyboard stopped working -- big problem
(02-02-2022, 08:54 PM)kaida Wrote: Did you try updating ? , cause for Arch , the current release has a broken onscreen keyboard and it's already fixed upstream but he hasn't made a new image yet , but a simple "sudo pacman -Syu" would fixed it
Thanks for replying. It is possible to check for updates via the Discovery application. There is no new updates. System is up to date; however will keep checking for new updates daily.
Note: It is not possible to check for updates via command because there is no onscreen keyboard, not even an Enter key.
Received update this morning and this issue is fixed on my PPP running the stock os with kde/plasma.
(02-02-2022, 08:54 PM)kaida Wrote: Did you try updating ? , cause for Arch , the current release has a broken onscreen keyboard and it's already fixed upstream but he hasn't made a new image yet , but a simple sudo pacman -Syu"" would fixed it
You can't do a  " sudo pacman -Syu" with no keyboard available
I found no solution to no keyboard so I went back to a dev version of plasma-manjaro-pinephone pro and I am running from the sd card.  Perhaps that has the update to fix the keyboard issue as discussed above but phone including keyboard is running again.  Lost all the setup I had done on eMMC version though.
Version running ok including keyboard is:  manjaro-arm-plasma-mobile-dev-pinephonepro-202220201.img.xz
tom kosvic
I was able to fix the keyboard issue by connecting a bluetooth keyboard that I have. So if you have one lying around, just connect it, then open up a terminal and type
sudo pacman -Suy
There was just one single package available when I did that today and it has fixed my onscreen keyboard. You could probably do the same when you have the pinephone keyboard accessory case.
I hope this helps.
bluetooth keyboard / usb-c to usb adapter..
For me the controls on my screen keyboard
Do not work.
Unable to execute CTL + C or CTL + W if you are
In terminal for example with nano
  Back/World camera working after suspend DrYak 2 878 11-14-2023, 09:44 AM
Last Post: DrYak
  Arch SXMO Stopped Booting After A Megi Linux Update. mburns 0 465 11-07-2023, 09:52 AM
Last Post: mburns
  tow-boot installation problem techariah 2 1,499 02-16-2023, 02:50 PM
Last Post: techariah
  Netfilter not working on latest manjaro kernel robocone 1 1,191 12-29-2022, 09:11 PM
Last Post: robocone
  Battery meter slowly reducing under keyboard charger robocone 1 1,370 12-26-2022, 09:37 AM
Last Post: robocone
  Monjaro Plasma Cell Network and Data not working properly maiyuzhe 2 1,590 09-24-2022, 12:15 AM
Last Post: maiyuzhe
  Manjaro 5.17.5-1 Keyboard stopped working Yst 7 3,928 06-09-2022, 11:12 AM
Last Post: graphicpanda444
  Fix keyboard layout robocone 1 1,750 05-16-2022, 08:03 AM
Last Post: robocone
  Plasma Mobile navigation bar scaling is not working Yst 0 832 05-09-2022, 05:10 AM
Last Post: Yst
  Screen keyboard Japanese input issue Yst 1 1,203 04-30-2022, 09:13 PM
Last Post: TRS-80
