PPP no audio except phone
I’m on Day 2. The phone works though not very cleanly (Mint Mobile) but I have no other audio - no YouTube in browser, no radio in Shortwave, no sound in cnn clips. It’s not muted and Settings aren’t helpful. Advice? Maybe some CLI commands?
What operating system ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(02-02-2022, 08:12 AM)bcnaz Wrote: What operating system ?
Default - Manjaro-ARM, 5.16.2.2, KDE Plasma 5.23.5
You may want to try booting another distro from an SD card. The stock Manjaro Plasma image is very buggy and does not run well at all in my opinion. I am running Arch Phosh and I have no issues with audio on calls or YouTube.
View my projects at: https://gitlab.com/users/The3DmaN/projects or at the3dman.gitlab.io you can also find me on Matrix in many of the Pine related channels.
I'm a little wary of that. The word "brick" seems to be coming up a lot when people try to use SD cards. The boot system to be vulnerable to people as clumsy as I am. I'd like to wait until it's a little more routine.
Using an sd card will not damage your existing installation, unless you choose to DO it, just using the sd card will not do any damage.
When you remove the sd card, that system is no longer on your phone. (your original installation on the eMMC is un-touched)
----> using Linux means the choices are always your own to make.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
When I tested the default os I had the same problem with audio. I also flashed Arch Phosh on an SD card and have no problems now. It's a pretty simple process, even a newbie like me can manage. Blush Good luck.
You guys talked me into it. I'm running Arch Phosh now and it seems a lot better to me. I'm running it off an SD card now. I assume that's the reason I could not download new apps right? Is there a cheat sheet for just putting it on the phone and dumping Manjaro Plasma? I don't understand booting, either on my Ubuntu laptop or on the phone. Mainly what I understand is if I mess it up I'm SOL.
The Flashing software works perfect for all the original Pine phones,  however that will not work on the PRO series...!
We are WAITING for the image that is Compatible  with the PRO series of phones.
(02-01-2022, 09:22 PM)IHaveALinuxPhone Wrote: I’m on Day 2. The phone works though not very cleanly (Mint Mobile) but I have no other audio - no YouTube in browser, no radio in Shortwave, no sound in cnn clips. It’s not muted and Settings aren’t helpful. Advice? Maybe some CLI commands?
I guess you can mark this thread as fixed or closed ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
I've been trying sailfish in SD with no problem and then manjaro again (in emmc)
I've done it today 10 or 15 times and no problem.
Question Phone call with the pinephone pro dfs 5 4,240 02-10-2024, 09:54 PM
  PPP used with smart phone gaming fan. DaForest 3 829 11-19-2023, 05:17 AM
Last Post: crocspot
  Is the pine phone usable as a daily driver now? gautamb11 18 4,453 10-27-2023, 12:46 AM
Last Post: gregb49
  Pine Phone Pro: Mobian+plasma mobile GabrieleMax 2 1,560 04-30-2023, 05:03 AM
Last Post: diederik
  pine phone pro won't start robb777 2 1,393 01-25-2023, 04:38 PM
Last Post: emsyr
  Current State of PIne Phone Pro kmsgli 40 25,829 12-23-2022, 06:44 PM
Last Post: Simon Belmont
  Was the Pine Phone Pro you got from DHL new? theForce 3 2,035 10-31-2022, 04:26 PM
Last Post: fxc
  Internet is not working on Pine Pro phone caroljames972022 0 873 09-16-2022, 06:25 AM
Last Post: caroljames972022
  Loud echo on receiving phone when called TheRealThor 3 2,119 08-09-2022, 10:09 AM
Last Post: tckosvic
  Phone not reading sim For_lack_of_a_better_name 6 4,246 06-09-2022, 01:00 PM
Last Post: daveman1010220
