New phone - Only red/green light. No boot.
I have a new pine64 and once unpackaged, removed battery plastic, attempted to power on. Only red/orange indicator appears, black screen. Inserted micro sd with mobian image and got a green indicator but still black screen.
Would really love to get this bad-boy up and running! Thanks!
(02-01-2022, 05:39 PM)migaligaz Wrote: I have a new pine64 and once unpackaged, removed battery plastic, attempted to power on. Only red/orange indicator appears, black screen. Inserted micro sd with mobian image and got a green indicator but still black screen.
I have the same problem. Completly new phone aswell.
After searching around i think the problem is with the battery beeing completly discharged, and the phone beeing unnable to charge the battery while beeing turned off.
( I dont know if this is the case, or the whole story )
If you have a seccond device or some way to charge it, maybe that will work.
Quote:If the battery is fully drained U-Boot might fail to boot any installed operating system on the eMMC and microSD card due to a bug.
If that's the case please start your phone in Maskrom mode and let it charge in that for a few hours. To do that:
  • Remove any microSD card from the phone
  • Hold the "RE" button underneath the back cover of your Explorer Edition (or shorting the bypass contact points on the Developer Edition)
  • Connect the phone to an USB port of a computer, while still holding the button
  • Check if the phone in Maskrom mode appears in the output of the Linux command lsusb on the computer (if the device disappears again please use a different cable)
  • Let the phone charge for multiple hours
Note: If that didn't work, try to remove the battery and the USB cable and hold the power button for a few seconds and then insert the battery again, before retrying the procedure.
From the PPP Wiki. Hopefully that helps, I found just using a 5V 3A charger and waiting a bit also did it for me.
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 713 02-17-2024, 04:04 AM
Last Post: fxc
Question Phone call with the pinephone pro dfs 5 4,232 02-10-2024, 09:54 PM
  PPP used with smart phone gaming fan. DaForest 3 821 11-19-2023, 05:17 AM
Last Post: crocspot
  Is the pine phone usable as a daily driver now? gautamb11 18 4,420 10-27-2023, 12:46 AM
Last Post: gregb49
  Manjaro Phosh - Tiny Blue Indicator Light - Blinking ArchiMark 0 735 06-09-2023, 12:55 PM
Last Post: ArchiMark
  Pine Phone Pro: Mobian+plasma mobile GabrieleMax 2 1,559 04-30-2023, 05:03 AM
Last Post: diederik
  pine phone pro won't start robb777 2 1,393 01-25-2023, 04:38 PM
Last Post: emsyr
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,185 12-31-2022, 09:14 AM
Last Post: mburns
  Current State of PIne Phone Pro kmsgli 40 25,814 12-23-2022, 06:44 PM
Last Post: Simon Belmont
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 2,838 11-20-2022, 05:58 AM
Last Post: wibble
