Powering Pinecil using an Artis 65W laptop adapter
Hi
I recently got a Pinecil. I was wondering if I can use the Artis 65W USB-C laptop charger to power it. The adapter specs is as follows-
Quote:Power Output: 5V/2.4A, 9V/3A, 12V/3A, 15V/3A, 18V/3A,20V/2.25A, and 20V/3.25A, Max Power Output: 65Watts
AC Input : 100V-240V( 50-60 Hz)
Compatible with all type C Laptops
Over Voltage / Over current Protection , Short Circuit/Overload protection, High Temperature Protection
Certifications: CE, FCC, ROHS, BIS (India) Certified.
The 65W charger is able to provide 3.25A @ 20V which seems to be same as the PinePower 120W Desktop Power Supply USB-C output. The manufacture has mentioned that it could be a little too much power for the Pinecil.
Here is the product url-
https://www.amazon.in/gp/product/B095PJY...p_hza?th=1
Here is the manufacturer's reply-
https://www.amazon.in/ask/questions/TxG6...pmw_al_hza
Please let me know.
(01-29-2022, 02:07 PM)werty37 Wrote: The 65W charger is able to provide 3.25A @ 20V which seems to be same as the PinePower 120W Desktop Power Supply USB-C output. The manufacture has mentioned that it could be a little too much power for the Pinecil.
Why would it be too much power?
I assume it is a PD-capable charger, so Pinecil can request 20V and it is able to provide up to 3.25A for Pinecil - generally it should be a perfect fit.
Anyway, 45W charger should be too low to fully utilize Pinecil, as far as I know, its full power consumption is around 60W at 20V.
(For 60W power at 20V, it would need 60W/20V=3A of current.)
Also, basically a power supply can supply a voltage (like 20V) and up to a specified current (A).
So looking at this perspective, the higher current is better and it should work together with Pinecil if it can supply at least that amount of current (or above) what Pinecil need.
So, do not buy a 45W charger for Pinecil.
In this case, actual power (W) comes from voltage (V) multiplied by current (A) and current depends on the device connected and not on the power supply itself (if it is capable of delivering the needed value).
Hi
The manufacturer has confirmed that it is not a PD-capable charger.
https://www.amazon.in/ask/questions/Tx1D...pmw_al_hza
Quote:I assume it is a PD-capable charger, so Pinecil can request 20V and it is able to provide up to 3.25A for Pinecil - generally it should be a perfect fit.
@VaZso Do you still think that I can use it to power the Pinecil and hopefully not damage it?
(02-02-2022, 05:54 AM)werty37 Wrote: Hi
It should be either a QC or PD-capable charger and both should be okay for Pinecil.
For QC, my Baseus chargers needed a timeout setting for PD negotiation timeout which is part of the latest firmware update but it works well by setting this timeout to 15.
As of QC protocol, there are a very few chargers which support 20V over QC (although I have such a charger, so it exists).
However, Type-C capable notebooks work over PD protocol, so if this charger really supports "5V/2.4A, 9V/3A, 12V/3A, 15V/3A, 18V/3A,20V/2.25A, and 20V/3.25A, Max Power Output: 65Watts" as they state, it should be a PD-capable charger (power supply).
However, I am not surprised at anything since I saw there are "notebook chargers" which have 12V output over Type-C connector without any negotiation (they should not exists anyway).
As of seller replies who has recommended a 45W or 30W charger for something which would need 20V * 3A = 60W, I would not think to know too much information about the product to be sold...
If it is either a QC or PD power supply, it should work... but based on the supported voltages, technically it should be one of them (definitively PD for notebooks).
However, it is another question if the power supply is really can provide 65W power output...
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 16 Yesterday, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 372 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 782 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 368 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,257 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 662 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,285 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,549 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,444 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,244 12-14-2022, 01:03 AM
Last Post: River
