UFW
I got errors on installation. I uninstalled it. Any one with solutions? Also impossible to install opensnitch
It would help to know what OS you are using.
Ufw works fine on Mobian.
Example:
sudo apt install ufw
sudo ufw enable
Then customize your settings.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
(01-28-2022, 10:21 AM)dachalife Wrote: It would help to know what OS you are using.
Example:
sudo ufw enable
No. I am using the default Manjaro in PPP
Sorry can’t help with Manjaro, didn’t like it; poor battery life & not for me.
