Pinephone pro Explorer teceived
Hi. I received today my Pinephone pro explorer. I installed I and found some advises and a little bit problem that I want to share with you. I already put then in pine64 telegram but I did not know about the forum. So I will put it here as well for you to know
I continue telling things
I started default installation and at the very end a message that there were updates
I click yes but I received and advise that no update was possible, the reason
Databases locked. A I am new to Linux I went to Google and ask or a solution and somebody gave it to me. " Shutdown, startup again and then
Open the terminal and write
Sudo pacman-db-upgrade && Sync
And " it worked" . Updated but with some warnings
That I will write down here for you to know and some help just in case
(01-27-2022, 10:28 AM)Emilio Wrote: I continue telling things
  PinePhone Pro silver lining, it’s fast, real damn fast ashoka232 0 208 03-20-2024, 01:45 AM
Last Post: ashoka232
  PinePhone Pro Black Screen CrimsenRaven 2 251 03-16-2024, 11:40 AM
Last Post: tmoj
  PinePhone Pro Review tmoj 2 418 03-14-2024, 07:14 AM
Last Post: tmoj
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 574 02-17-2024, 04:04 AM
Last Post: fxc
Question Phone call with the pinephone pro dfs 5 4,004 02-10-2024, 09:54 PM
  Average Joe review of Pinephone Pro (March 2023) alaraajavamma 6 9,870 01-06-2024, 11:32 AM
Last Post: mikehenson
Question T-Mobile and Pinephone Pro in the US jydoxcen 4 662 01-02-2024, 09:08 AM
  Pinephone Pro Screen Protector jydoxcen 11 1,137 12-21-2023, 07:58 AM
Last Post: zetabeta
  Pinephone Pro does not start with RE button pressed c0ssan 10 5,075 09-28-2023, 09:21 AM
Last Post: R0bbi3Mack
  Is my pinephone pro worth resurrecting? tckosvic 5 2,824 09-14-2023, 06:48 AM
Last Post: DaForest
