How to get control of GPIO pins from Remix?
I would like to make a very small app or script to Android / Remix.
It shall set a GPIO pin high for 0.5 to 1 second and the low again.
Why? I would like to reset the HP_Jack connector status and thereby be able to use the audio output without doing the unplug-plug manual sequence after power up. (with a relay or analog sw. will I shortly connect pin 3 and 4 at the jack connector.)
A manual short circuit of pin 3 and 4 (and release again) activates the audio output af the HP_JACK connector.
So:
  • How do I get started making a simple app or script to android?
  • How do I get control of the GPIO pins from android?
check this thread: http://forum.pine64.org/showthread.php?tid=1750
  GPIO access running Android rddragon888 20 28,480 11-06-2017, 07:18 AM
Last Post: Anvesh Reddy
  Guest Account Cannot Access Internet on Remix OS and Android x-86 OS deniyulianti 1 3,061 10-21-2016, 05:38 AM
Last Post: MarkHaysHarris777
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 0 2,489 10-15-2016, 06:32 AM
Last Post: deniyulianti
  question about burning Andriod/Remix images--Phoenix image first? bigben 4 7,302 07-19-2016, 04:28 PM
Last Post: Ghost
  Any luck using GPIO's ? Skivholme 2 2,882 05-18-2016, 10:13 AM
Last Post: Skivholme
  Slow Internet connection android 5 and remix os lucassou 3 6,483 05-01-2016, 12:54 AM
Last Post: mattcozi
  Getting Android source under version control jonsmirl 4 5,169 04-17-2016, 08:47 AM
  API for controlling GPIO pins from Android apps Ghost 5 10,009 02-29-2016, 02:54 PM
