£20 GaN Charger - works straight out of the box.
Thumbs Up
Just received my Pinecil and 1.5m silicone cable.
Bought this GaN charger on Amazon for £20 (1 port version), plugged it in and it worked no problem:
https://sumvision.com/product/sumvision-...t-charger/
No sure if the Pinecil voltage needs calibrating, or whether the charger is outputting at just under 20v - will do some testing and update.
Might be worth adding to the list of compatible PD chargers (I recall seeing a list on Wiki I think?).
feel free to add that to the list in the wiki, if there is one. your forum login doubles as your login for the wiki.
(01-26-2022, 12:55 PM)tophneal Wrote: feel free to add that to the list in the wiki, if there is one. your forum login doubles as your login for the wiki.
Super - thanks.
Turns out I had to calibrate the Pinecil (it was reading circa 19.5v). Voltage reading (taken from the barrel connector whilst USB-C connected to the GaN charger) is bang on 20v, so calibrated the Pinecil to match.
Getting close to 50w for such a small charger is great, the whole package becomes very portable. ?
  Usability with 20w charger nixcamic 1 2,319 11-15-2021, 08:25 PM
Last Post: VaZso
