XFS Support?
I can see a commit to enable XFS as a module but I cannot find the module.
root@pine3:/var/log/ceph# find /lib/ -name "*xfs*" -print | wc -l
0
root@pine3:/var/log/ceph# modprobe xfs
modprobe: FATAL: Module xfs not found in directory /lib/modules/3.10.102-0-pine64-longsleep
Is there some other way to install XFS support?
Thanks @longsleep for your continued hard work!
I just build XFS as a module based on the latest longsleep kernel, so I guess it's just a question of enabling it in the config for the next release...
No, if you enable xfs then other stuff is disabled. Check the commit history - I had it enabled before.
  Programming languages support under PINE64 baryluk 6 12,300 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  AXP803 Battery Charger Support xalius 14 24,087 12-22-2017, 08:59 AM
Last Post: Velociraptor
Wink Pine64 Will support Freenas or openmediavault ? joe 1 4,970 04-13-2017, 07:44 AM
Last Post: xalius
  Remote Desktop Support? Rochambeaux 20 29,246 10-01-2016, 05:08 PM
Last Post: HayseedGeek
  Binfmt_misc support cztian 1 3,698 08-17-2016, 11:49 PM
Last Post: longsleep
Question Joystick/Gamepad support Drakuwa 3 5,978 08-10-2016, 10:12 AM
Last Post: xalius
Big Grin Funny ! Support Intel x86 linux applications on ARM-based ( PINE64 ) not freeware joe 10 16,390 08-09-2016, 05:59 PM
Last Post: dkryder
  Camera support - Ubuntu Xenial 16.04 LTS @lex 3 5,214 08-07-2016, 03:47 AM
Last Post: romansavrulin
  Virtualization Support soccercheng 12 17,401 07-14-2016, 11:04 AM
Last Post: mont3z
  distro with kernel support for DVB-T dongles? mkaut 2 4,612 07-02-2016, 02:36 PM
Last Post: mkaut
