Boot order
I don’t really understand the boot system but I have one knowledge tidbit to contribute. I lost track of things and let my PPP battery go to zero. I plugged it in and it booted to Arch which is on my SD card. I did nothing knowingly to my original default OS.
(01-31-2022, 01:19 PM)Conjada Wrote: FWIW, I and others have found that our PPP's will boot to SD without doing anything, other than inserting the SD card. I don't know why this would be. After I booted into ArchLinux Phosh, I went ahead and wiped out the eMMC as per the wiki, so I can't test that anymore. But, it DID boot to SD without pushing any buttons at all.
+1 - I never pressed RE, and have run five different OSes from my SD card in the two days I've had my PPP. Happily booting back into the default OS just by removing the SD card.
(02-05-2022, 02:09 PM)kaida Wrote: basically , the PPPEE , will check the emmc for boot ,
The preloaded manjaro has a special version of uboot that will check SD First before booting itself , but if you wipe it and nothing is on the emmc then the SD will also boot ,
if you flash something else to the emmc then the SD won't boot and if it brick then you need to press the reset button under the cover to boot back on a sd card .. so yeah really easy in all scenario
This appears to answer the riddle, but perhaps this should be documented clearly somewhere so it's not so mysterious to users?
(03-05-2022, 03:46 PM)amartinez Wrote: This appears to answer the riddle, but perhaps this should be documented clearly somewhere so it's not so mysterious to users?
Uh, it is documented? https://wiki.pine64.org/wiki/PinePhone_Pro#Software
Yeah , the reason I could answer is because I've read the docs..
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 715 02-17-2024, 04:04 AM
Last Post: fxc
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,185 12-31-2022, 09:14 AM
Last Post: mburns
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 2,840 11-20-2022, 05:58 AM
Last Post: wibble
  Tow-Boot issue Barugon 1 1,347 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  pinephone pro boot: kernel image not aligned on 64k boundary kmerfeld 2 2,035 08-15-2022, 10:35 AM
Last Post: ajaso
  pinephone pro don’t boot anymore :/ (I erased bootloader by mistake) elode 9 4,853 06-20-2022, 11:16 AM
Last Post: elode
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 7 5,922 05-21-2022, 01:24 PM
Last Post: 98cwitr
  My new Pinephone Pro does not boot any more jlioret 3 2,546 05-21-2022, 12:08 PM
Last Post: 98cwitr
  Tow-Boot on PP vasir 1 1,274 04-28-2022, 05:22 PM
Last Post: vasir
Thumbs Down Will it ever be able to order PinePhone pro from India? rksomayaji 4 2,753 04-01-2022, 03:25 PM
Last Post: nande
