Header bar date/time vs time-only option
Hi folks,
I noticed a picture on Twitter showing that Manjaro allows showing date and time instead of only time on the header bar in Phosh. Does anybody know what enables this? Is there an option that I'm missing in Mobian? Or a package missing in Mobian to enable this?
Thanks!
(01-14-2022, 02:40 PM)You cKorac Wrote: Hi folks,
Thanks!
This can be easily changed through the PostmarketOS tweaks app which is also available on Manjaro, but not on Mobian I think. You can change the corresponding dconf settings though (e.g. through dconf-editor if you want a GUI) which can be found under org.gnome.desktop.interface (the relevant ones are clock-show-weekday, clock-show-date and clock-show-seconds).
To achieve what you want through the terminal use this command:
gsettings set org.gnome.desktop.interface clock-show-date true
Splendid! Thank you for passing that along!
  [solved] Black screen at boot time mdk 0 961 01-13-2023, 03:33 AM
Last Post: mdk
  Time is wrong after reboots stucked at 27th august user641 2 1,225 09-08-2022, 01:39 PM
Last Post: user641
  Date & Time-setting app is a very poor design treebeard 6 3,194 07-27-2022, 06:35 AM
  22 July 2116 -- wrong Date & Time Anna 7 5,883 07-30-2021, 07:29 PM
Last Post: bcnaz
  Does anyone wish there was a 150% display option? lovepine88 2 2,484 06-12-2021, 12:47 PM
Last Post: lovepine88
  Re-do First Time Setup / Location Services Setting (How?) calinb 3 3,921 01-01-2021, 08:03 PM
Last Post: calinb
