New Keyboard Questions
(01-13-2022, 10:09 AM)ragreenburg Wrote: I think the answer is yes. I don't know the knowhow of it but I think it basically just checks if the keyboard is attached on boot then goes from there. I think you can still charge the phone without having to reboot it but to use the keyboard you need to turn it off then on again. Easy workaround, don't ever take the keyboard off...
I haven't checked (nor I have received my keyboard yet) but I would think if it checks the keyboard at boot time then it should be booted while the keyboard is attached and it may be removed / reinserted later so I would think it may work. Smile
However, it may happen it periodically checks if it is attached but then I would ask why it does not check for it periodically on absence. Smile
Anyway, I would also think related kernel module and / or user application may be started later so connection should be possible also on a working system but its automatism is what is missing. Smile
You very well might be right, I am know they said it has to be on during boot and my keyboard is still in china so I can't test either.
  keyboard case charging but not typing new2pinephone 18 5,217 02-19-2024, 07:30 AM
Last Post: theResonant
  Keyboard doesn't charge my phone no matter what, so can I charge my phone directly ragreenburg 3 5,606 01-14-2024, 03:34 PM
Last Post: acid andy
  I've added an I2C connector to the PP keyboard eugenr 0 359 11-26-2023, 07:24 AM
Last Post: eugenr
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 7,905 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 392 10-22-2023, 03:39 PM
Last Post: rotwang
Exclamation USB mouse isn't working when a PP keyboard is attached? mikeb 3 1,113 10-21-2023, 08:21 PM
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 449 10-21-2023, 07:50 AM
  Which mini keyboard and mouse to choose for the PP? Peter Gamma 0 562 10-21-2023, 02:55 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 905 10-20-2023, 04:11 PM
Last Post: mburns
  How to disassemble Keyboard top and replace cables? elof 2 719 10-11-2023, 09:03 AM
Last Post: elof
