Powering the modem after turning off the smartphone
Question
Hello.
I don't understand well in block diagrams, but looking at "PinePhone v1.2b Released Schematic.pdf" I see that the modem is connected directly to the battery.
Will the modem have power after turning off the smartphone?
The modem contains a single-core ARM CPU running a Linux-like OS.
The OS on the phone needs to task the OS on the modem to shutdown, when the OS on the phone is being shutdown.
In both OS, power is connected to the phone hardware (other than modem) and modem hardware even when both are shutdown. If both OS are shutdown, then neither is using power or using the battery or causing the battery to drain. There have been cases when the phone OS has shutdown while leaving the modem OS running causing the battery to drain.
(01-05-2022, 07:29 AM)lot378 Wrote: The OS on the phone needs to task the OS on the modem to shutdown, when the OS on the phone is being shutdown.
Thank you. And where can you read about these requirements. Is it from some document?
I studied the suspend/resume protocol of the modem recently. It is not about powering down as you asked, but the links I collected may be useful for you.
I think I saw the related code in both Modem-power kernel driver and eg25-manager sources.
https://github.com/NixOS/mobile-nixos/is...1028385001
  Supported Carrier and Modem Bands NachoMomma 4 1,507 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 488 02-17-2024, 04:15 PM
Last Post: vortex
Bug PinePhone modem keeps "disappearing" Kevin Kofler 14 5,506 03-22-2023, 05:28 PM
  modem not working michelinux 0 908 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 4,177 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 5,307 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 2,784 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 4,043 06-13-2022, 04:12 AM
Last Post: zetabeta
  Modem Hardware bad? Not ready for 5g?? linux76 8 4,644 05-31-2022, 06:41 PM
Last Post: SwordfishII
  Modem in failed state, not sending/receiving SMS brb78 5 3,620 03-31-2022, 08:37 AM
Last Post: wibble
