Firefox-esr 91.4
Hi folks!
If you you find firefox 91.4 very sluggish on scrolling on some websites, you could try to set the following in "about:config":
gfx.webrender.force-disabled=true
according to mobian webside this should help also, although I found it makes little difference, if any:
layers.acceleration.force-enabled=true
On my PineTab it was a notable improvement. Hope that helps.
