How to open a terminal on my PC to the PinePhone?
When I connect my Librem 5 to a Linux PC via a USB cable, I can use the command picocom /dev/ttyACM0 on my PC to open a terminal inside the Librem 5. This is very convenient, since it allows me to use my PC's screen and keyboard and to easily cut and paste into the Librem 5 terminal.
However, I can't figure out how to get picocom to work with the PinePhone. How can I open a terminal in the PinePhone on my PC?
I'm currently running Mobian, but I would be interested in hearing solutions for other operating systems as well.
【On your phone】
sudo apt install ssh
sudo systemctl enable ssh
Then check your IP address (should be 192.168.x.x, 172.16.x.x, or 10.x.x.x, replace "x" with whatever shows up).
ip a
【On your PC】
ssh mobian@(IP address of your phone)
Then to skip the password (optional step, but very convenient if you frequently login):
【On your PC】
cat .ssh/id_rsa.pub
(Copy the output, if there is none or an error message, generate your SSH key.)
【On your phone】
mkdir .ssh # If not done already
nano .ssh/authorized_keys # or vi .ssh/authorized_keys, or vim .ssh/authorized_keys, or mcedit .ssh/authorized_keys etc.
(Paste the output you copied and save the file.)
母語は日本語ですが、英語も喋れます(ry
If you really want a serial terminal rather than ssh you'll need to check how they configure the USB gadget mode. This is more of a pointer for research than a set of instructions as I don't know the details. There's an example in the Mobian wiki for changing between different networking gadgets at runtime using entries under /sys/kernel/config/usb_gadget/g1
https://wiki.mobian-project.org/doku.php...ws-via-usb
There should be a similar way to add a serial gadget.
Once you have a serial interface you need to start getty or similar on the serial port, whether manually or using a service file like getty@ttyGS0.service
  PinePhone - boot from microSD laserpyramid 6 538 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 340 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 228 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,882 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,776 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 599 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,333 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 491 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,678 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,935 12-04-2023, 02:14 AM
Last Post: Peter Gamma
