Kodi on Pinephone
If you look in the software repositories of your Pinephone compatible distro the FOSS app Kodi is probably found if installing desktop apps are enabled.
Kodi is more a framework for plugins from commercial subscription streaming to game emulation and many others, it comes with with a built in multimedia playback capability which can play most media files.
The one difficulty I have found with using Kodi for playback vs any other media player including the stock one in Mobian is that the Kodi mobile skins I have tried to use expect an android home key or something else emulating a backspace.
Is there anyone who has found an easy to use skin for Kodi which provides the missing [back] signal somehow?
Any other Kodi related ideas especially reducing the battery usage for video playback(better utilizing hardware decoding?) would be appreciated!
How easy is it to fork a kodi skin to add a back button? I've not tried, so for all I know there are gotchas along the way.
https://kodi.wiki/view/Skinning_Manual#Button_Control
If it could be made configurable, or autodetect whether to show the button, an existing theme might accept a patch. Some themes have turned down similar requests as they consider it out of scope though ("We target remote controls. If you're using a mouse then pick a different theme." and similar)
(11-28-2021, 04:39 AM)wibble Wrote: How easy is it to fork a kodi skin to add a back button? I've not tried, so for all I know there are gotchas along the way.
Thanks, sadly I didnt see a way to insert a back/backspace into a customized skin.
I hate to follow down the android style route but maybe hacking together a custom keyboard map for multimedia remote controls as a KB option, but then there would be a way to easily control kodi.
There would still be the issue of using up most of the battery with a 1 hour video, same problem if I can coerce VLC to play a video; the stock Totem based Videos player in Mobian has never played a video for me so remains untested, but years ago Totem was one of the first apps I would uninstall.  I suspect this is due to CPU vs GPU decoding of the stream.
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 24,818 Yesterday, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 3,873 Yesterday, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 435 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,381 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,304 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 1,991 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 101,723 11-17-2023, 08:37 AM
Last Post: Uturn
  Using Signal on PinePhone in mid-2023? dante404 45 13,100 11-17-2023, 04:23 AM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 974 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,205 10-24-2023, 08:57 AM
