Can't install arch-phosh with dd, only with etcher.
When I run
dd if=archlinux-pinephone-phosh-20211022.img of=/dev/sda2 status=progress
the phone, when the uSD card containing jumpdrive is taken out, takes a forever loading screen with the arch penguin.
when I run ./balenaEtcher-1.5.115-x64.AppImage, I write archlinux-pinephone-phosh-20212022.img to /dev/sda2. Once I take jumpdrive out and restart the phone, the boot process begins with regular text moving through the screen. I now have the phone set up as I had before with everything being accessible and working after I go through the lock screen.
What could be the problem here? Could this be a sign of future problems with the phone's installation with balena etcher as well as other installation methods on my pinephone?
sda2 is a partition within your drive/sd card, you need to write it to the whole device (sda) instead.
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
(11-20-2021, 02:42 AM)pineuser0 Wrote: ...
I'ld add a bs=4M to that command to speed it up a bit as well.
As Danct12 points out, you need to use the base partition of your target drive, which according to you is /dev/sda.
As in:
dd if=archlinux-pinephone-phosh-20211022.img of=/dev/sda bs=1M status=progress conv=fsync
Then, before rebooting don't forget to resize the resulting 2nd partition:
(with jumpdrive still operating, and issuing command from host linux computer):
parted /dev/sda
(parted) resizepart 2 100%
(parted) quit
Otherwise you won't have access to the full available disk space on the emmc drive. Strange, the Mobian system takes care of this by automatically resizing on first boot, but Arch and Manjaro seem to leave it up to the user.
(11-23-2021, 01:36 AM)cabbie001 Wrote: the Mobian system takes care of this by automatically resizing on first boot, but Arch and Manjaro seem to leave it up to the user.
No? The file system gets resized automatically on boot.
HOLD YOUR BREATH.
Well if that's true then I'm happy to learn it.
My comment was based on the experience that only Mobian seemed to send out a notification alert during first boot that the partition re-sizing was happening.
If Arch also does then then I stand corrected. Thank you.
  stuck between phosh and plasma aular 0 219 02-27-2024, 05:55 PM
Last Post: aular
  Updating Arch Linux _radv_ 8 772 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,219 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 758 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,906 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,837 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 896 07-29-2023, 08:27 AM
Last Post: alpineduck
  unable to install applications dln949 5 1,493 06-08-2023, 08:38 PM
Last Post: Conjada
  Latest update broke my install user641 8 3,650 02-22-2023, 05:54 AM
Last Post: gregb49
  new to pacman. Trying to install VIM, getting a 404 when it tries to download. willyray 1 1,135 12-24-2022, 11:00 PM
Last Post: shulamy
