constant apk error message
every time  i  do a "sudo apk upgrade" I get the following message:
1 error:  1683 MiB in 727 packages
That is the only message and it is always the same.
Must have messed something up in some package, but can't figure out which one.   Anyone have any idea what I've done wrong and how to fix it?
Correction: last upgrade I did was "sudo apk -U upgrade" got:
1 error:  1686 MiB in 732 packages
I keep trying to add packages and am being told ; "temporary error ( try again later)" getting a little annoying! Has to do w. man pages.... I think.
Lookng for ways to find which package(s) are the cause of the errors and why.
sudo apk fix/ sudo -U upgrade fixes nothing
(11-11-2021, 12:43 AM)iwm Wrote: every time  i  do a "sudo apk upgrade" I get the following message:
Think it has to do with not having "edge" in my repo file.
Re-flashed and started over.  Working (updating, upgrading) fine now.
  where are the message notification ringtones? shengchieh 3 1,147 07-01-2023, 08:25 AM
Last Post: AndyM
  Error when updating syrinx 1 2,346 03-06-2021, 01:32 AM
Last Post: hiimtye
  pmbootstrap error lat 2 3,505 12-22-2020, 06:32 PM
Last Post: lat
  chroot can't execute passwd exec format error dimm82 5 5,956 09-18-2020, 07:53 AM
Last Post: krsmith28p
Sad ERROR: Could not find dependency 'firmware-rtl8723bt' Engineer 4 6,082 06-16-2020, 12:29 PM
Last Post: Engineer
  Error importing PyQt5 bunburya 9 9,549 02-25-2020, 06:02 AM
Last Post: PureTryOut
