Screen and Digitzier
Two dumb questions!
1. Is the screen and digitizer a combined unit or are they separate?
2. Does (1) in the document below do anything other than protect the screen?
https://files.pine64.org/doc/datasheet/p...%201.0.pdf
I'm asking this because my Braveheart has just started playing up. I have difficulty touching some parts on the lower part of the screen, namely the area where the '6', 'y', 'h' and 'n' keys are located. The fault is intermittent.
If the digitizer is separate and/or (1) handles touch input, I was hoping to disassemble the phone and try re-seat either of them before ordering a replacement screen.
Many thanks in advance!
I'd try reseating the connector if you haven't done it already. Based on the 'Screen dying already?' thread I don't think there's a reasonable way for an end user to reassemble the screen assembly.
https://forum.pine64.org/showthread.php?tid=13636
(11-11-2021, 02:48 AM)wibble Wrote: I'd try reseating the connector if you haven't done it already. Based on the 'Screen dying already?' thread I don't think there's a reasonable way for an end user to reassemble the screen assembly.
Yep, tried that before posting. But thanks for the suggestion.
From your post, it sounds like I have to order a replacement screen.
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 352 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,272 10-12-2023, 01:03 PM
Last Post: robthebold
  Screen dying already? marcih 153 143,532 02-23-2023, 04:14 AM
Last Post: Shatur
  Screen Replacement Instructions erikkugel 4 3,087 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,578 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,706 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 3,974 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 29,005 01-18-2022, 12:21 AM
Last Post: henrythemouse
  pinephone screen Uturn 2 2,248 01-14-2022, 01:15 AM
Last Post: Uturn
  Screen replacement Csanderson0313 4 3,186 01-10-2022, 09:26 PM
Last Post: Csanderson0313
