Ribbon Cable Extenders ?
i bought this:
http://www.ebay.ca/itm/151985309073
FFC FPC 30-pin 0.5mm Pitch Ribbon Cable line ZIF HDD+Adaptor extend connector
totally works. worth the $4.
now, as you can see, that comes with the extending adapter, which you already have. so...
i also bought this:
http://www.ebay.ca/itm/311530317516
20Pcs 0.5mm Pitch 6 Pin AWM 80C 60V VW-1 Flexible Flat Cable FFC FPC 200mm
yeah, that's 20 of them. but i couldnt find less than that for any better price. getting just 1 was the same price as 20.
and i used the extending adapter from the other purchase to connect it
and now both cables for my lcd are really long and easy to work with.
(08-02-2016, 10:56 PM)jodybrown99 Wrote: yeah, that's 20 of them. but i couldnt find less than that for any better price. getting just 1 was the same price as 20.
How have you connected your touchpanel cable with the 30-pin-adapter?
Just on the same ports on each side?
Best regards
Julian
My forum topics:
• Create a WiFi hotspot on Debian 8
• Turn your Pine64 into a music server with mpd
• Adjust brightness of LCD on Armbian Desktop with 1 click
• My cases for Pine64 (acryl, lego & wood)
• Pine 64 - DACH - Facebook page for german-speaking Pine64-fans.
The cables should be inserted with the contact pads 'towards' the board or connector.
Alright, sound easy.
Thanks marcushh777.
This cable should also match the conditions for touchpanel, right?
- http://www.ebay.de/itm/FFC-A-6Pin-0-5Pit...1866201167
It's more expensive as the given product here in the topic, but I can't order the other cable for addresses in Germany or Austria :/
Best regards
Julian
My forum topics:
Best regards
Julian
(08-03-2016, 01:44 PM)JulianM Wrote: Alright, sound easy.
Thanks marcushh777.
Best regards
Julian
yes, exactly.
[Image: e93IO1g.jpg]
http://imgur.com/e93IO1g
and yes that cable you linked looks fine to me. i took a gamble but it works.
look for a multi-pack. you might actually find one cheaper. as mentioned, i could only find singles for more than it cost me for a 20-pack.
  Cable for LCD sbentjies 21 30,278 07-03-2016, 04:19 AM
Last Post: robpaz
