Inserting Existing Sim in PinePhone - No response? (Verizon US)
I'm trying to make the switch from an iPhone over to my new PinePhone, but when I insert my Verizon US sim card from the iPhone, the PinePhone doesn't seem to register that it is there. Do I need to get a new standard size sim card to make this work? I used the adapter thing, which was difficult at best, but looked like it went in there straight.
You need to contact Verizon customer support, and ask them to allow your PinePhone on their network. If you go to your "My Verizon" page, select "bring your own device", and check your PinePhone IMEI number, you'll find that it's not supported, but that's not the end of the line. Contact (call) customer support, and ask for help with a request form, they'll fill it out for you, and get back to you in a few days.
***   Don't be a minion in the (i)droid army   ***
(11-04-2021, 03:05 AM)Fred Zyphal Wrote: You need to contact Verizon customer support, and ask them to allow your PinePhone on their network.  If you go to your "My Verizon" page, select "bring your own device", and check your PinePhone IMEI number, you'll find that it's not supported, but that's not the end of the line.  Contact (call) customer support, and ask for help with a request form, they'll fill it out for you, and get back to you in a few days.
Excellent, I will give that a shot. Thanks!
  PinePhone - boot from microSD laserpyramid 6 550 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 345 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 230 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,926 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,783 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 602 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,340 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 493 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,680 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,943 12-04-2023, 02:14 AM
Last Post: Peter Gamma
