06-25-2016, 07:52 PM
See http://singleboard.org Feedback and suggestions appreciated
I started blogging on Pine64 Cluster
06-25-2016, 08:44 PM
(06-25-2016, 07:52 PM)salmangano Wrote: See http://singleboard.org Feedback and suggestions appreciated Nice blog and interesting. I like your writing style. I know some people made their own power supplies to power the board directly on some pins instead of the USB. However your solution looks nice. I do not know much about cluster computing (accept as a user) so I will be interested to read about your adventures
06-25-2016, 10:55 PM
(This post was last modified: 07-09-2016, 04:24 PM by lenny.raposo-pine64.pro.)
here's mine
If you like my work be sure to check out my site or wish to donate to the cause
Cheers
06-25-2016, 11:16 PM
Nice blog.
06-26-2016, 05:15 AM
After the dust settles, I think I'm going to make a cluster. :-). I have two pines already.
06-26-2016, 08:15 AM
hey salmangano just so you know all you had to do in order to change mac addresses was to change the entry in the /boot/uEnv.txt and if you take notice under the board it does display the actual mac address for that particular board.
Once you are done with you tutorial feel free to post it at https://www.pine64.pro
Cheers
06-26-2016, 08:34 AM
What are you going to do with cluster?
06-26-2016, 07:13 PM
(06-25-2016, 07:52 PM)salmangano Wrote: See http://singleboard.org Feedback and suggestions appreciated Thanks on the good article.
06-27-2016, 03:15 AM
@Lenny, NICE !
... what's with the single board outside the cluster tower? Which Lego set did you use... ad hoc blocks ? Really, very cool design (actually, that's the best I've seen so far)...
06-29-2016, 12:00 PM
(06-25-2016, 07:52 PM)salmangano Wrote: See http://singleboard.org Feedback and suggestions appreciated Good post, but I recommend manually resizing the pictures you've included in it. Takes a long time to load your page on a slow network since those pics are almost 10mb each in size.
Some with certainty insist no certainty exists.
Cluster Software | Madroxprime | 1 | 5,411 |
04-03-2017, 06:57 AM Last Post: Shad0wSt4R |
Cluster / Render Farm | Ron Piggott | 15 | 25,137 |
10-02-2016, 02:55 PM Last Post: tllim |
Bargain 5 Node Cluster of PINE A64+ from Climber.net | tllim | 8 | 14,496 |
10-02-2016, 07:01 AM Last Post: sheffield_nick |
Batch Schedulers on pine64 | cdslashetc | 0 | 2,923 |
07-24-2016, 09:19 AM Last Post: cdslashetc |
Pine64 Cluster economy | baryluk | 5 | 11,010 |
06-19-2016, 09:13 AM Last Post: JasperBrown |
cluster computing | jproffer | 20 | 35,918 |
05-05-2016, 04:13 PM Last Post: pineresearch |
Cluster capable? | W1SPY | 7 | 12,315 |
02-25-2016, 10:34 PM Last Post: hrh1818 |
